You will need FLARE nut wrench for the job, you will ending up rounding up the edge of the brake line nut and make the job more difficult if you use normal wrench for the job.
I did it once and i think you need size 10 FLARE NUT WRENCH. When you undo the bolt, try to a bit of gentle tapping on the wrench when undoing the nut.
Some thing like the item below which have more contact point compare to normal wrench:
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
