Online Now [560]:
Visitors: 559
Today: 200134
Total: 146655011
Forums › The Car › 206 Problems › speedo and odometer not working
Scotsman23
PostPosted: Thu Oct 11, 2012 5:04 pm Up
2002 peugeot 206 1.4 auto
The car drives fine and has been recently serviced but the speedo and odometer are not working?
ive taken the car to a garage that specializes in french cars thinking it was a faulty vehicle speed sensor, but the mechanic removed the sensor and somehow turned the spindle manually and got the speedo to function? he used the computer diagnostic tool but could find no faults
that airbag light is also on and the gear selector display is showing the car in park even when i am driving (not sure if its related)
any ideas would be gratefully appreciated?
chuckstar34
PostPosted: Thu Oct 11, 2012 5:38 pm Up
Hmmmm, Does sound like another sensor confusing the ECU, Maybe the gear position sensor? If its telling the ECU its in Park it may block the the speedo sensor info as it feels it doesnt need it.
Thats a good one
Chuckster.
Scotsman23
PostPosted: Mon Oct 15, 2012 9:51 pm Up
Thanks Chuckster
i also think it could be sensor fault maybe the throttle sensor? i need to find a good garage in SE london to take it as the last mechanic did not have a clue
i will update and let you know how i get on
Fozzmeister50
PostPosted: Thu Oct 25, 2012 5:26 am Up
I have recently bought a 1999 1.9 diesel great car but the odometer is not working its not lighting up on the dash display, any ideas
heyziq
PostPosted: Thu Oct 25, 2012 8:41 am Up
ecu+bsi probably
heyziq.com
