Online Now [284]:
Visitors: 284
Today: 96366
Total: 142479113
Forums › The Car › 206 Problems › Head gasket tools
Head gasket tools
Jay0913
PostPosted: Tue Oct 16, 2012 1:13 pm Up
Hi guys i was just wandering if someone could give me a list of tools i will need to change the headgasket along with the timing belt and water pump thatnks
Jay0913
PostPosted: Tue Oct 16, 2012 1:15 pm Up
Sorry its a 1.4 8v 2001
you serious?
Jay0913
PostPosted: Tue Oct 16, 2012 1:16 pm Up
Yes
PostPosted: Tue Oct 16, 2012 1:34 pm Up
torque wrench, hex sockets, e-sockets, hose clamp pliers, locking kit
drunknmunky
PostPosted: Tue Oct 16, 2012 1:44 pm Up
im not being funny but if you have to ask what tools you need to do it i doubt its a job you can do.......
PostPosted: Tue Oct 16, 2012 2:13 pm Up
Feeler gauges for valve clearances.
PostPosted: Tue Oct 16, 2012 2:14 pm Up
i would have though if you lock the pulley you don't have to measure that?
PostPosted: Tue Oct 16, 2012 2:20 pm Up
I thought that the 1.4 8V had adjustable rockers. Would you do head gasket without checking clearances and completing the work with a full service?
No one has told him to get the head skimmed yet. Will he know that?
Full service adds filter wrench (or screw driver and hammer) and is the sump plug a bolt needing a spanner or recess needing an allen key or similar?
Any special tools for resetting the cambelt tension?
Jay0913
PostPosted: Tue Oct 16, 2012 2:39 pm Up
I have a basic tool box, with sockets etc. i want to attempt to change it myself dont care if i mess it up, i dont want to stop half way needing a tool because i live far away from any tool shops, my friend said i need a certain tool to tight all of the bolt with the same tension, is there such a tool? Thanks
PostPosted: Tue Oct 16, 2012 2:45 pm Up
Torque wrench.
You need a Haynes manual for the differtent torque settings for the nuts / bolts.
Not sure if some are also angle tightened.
it has pretensioner in the timing belt kit so it doesn't need anything special.
yes...that's a torque wrench...
chuckstar34
PostPosted: Tue Oct 16, 2012 4:34 pm Up
Im always happy to help with advise on here if some one wants to attemp a fix or has a probably, but I have to say by the time youve spent cash on tools etc and then hope you fix my advise would be for you to take to a garage or get some one to be there with you who has a basic knowledge of changing a head on a car.
I know we have to start some where and stuff but i recon a head gasket on a first job its running before ya know how to suck ya thumb.
Mind you maybe you do have the knowledge and not the tools?
How do you know you need a head gasket out of interest?
Chuckster.
PostPosted: Tue Oct 16, 2012 6:30 pm Up
Head-bolts will need to be torqued-up to 25Nm first (torque wrench) then stage two is angle-tighten 270 deg (angle gauge).
All bolts have to be done in a specific order and you need to study a Haynes manual first, then pray you don't do more harm than good. Valve-clearance adjustment is a must as well imho and that requires skill and trial and error depending on the condition of the specific engine.
Not on a 2001 1.4i it doesn't.
Yes, that's right: 'Boom, snapy-snapy'
PostPosted: Wed Oct 17, 2012 7:58 am Up
looks like my engine is easier to work on Laughing
