Latest: Puggingalong
Overall: 17129
Online Now [249]:
Visitors: 248
Today: 1185
Total: 101358260
Forums › The Car › 206 Talk › clues abound but 206gti still wont start?help please??
bezford
PostPosted: Tue Oct 16, 2012 2:30 pm Up
my 02gti137 wouldnt start 3 days ago and i assumed it was petrol so next daY I PUT SOME IN AND IT STILL WOULDNT START?unfortunately i used too much battery trying to start her but ive got a jumper pack and ive had that on but still no start?
The car goes mad on lites and gauges then calms only for the fuel gauge to rise to above full while its actualy only got a quarter tank in it ,if that, then ignition lites come on with engine warning lite until i try to start fully?
(( prior to this problem the engine fault lite was on which has been on for ages now i was told to ignore it as it was just the lite at fault also ive had antipollution fault on screen for a while too and just 1 week ago had my front pipe welded to my cat to fix a blow,))but its been running fine despite all this stuff until the apparent petrol shortage
So i currently have madness then engine lite and fuel gauge over full and warnings including now" immobilizer fault" on screen,now plenty of fuel and charger/jumper on i try to turn over to start and it seems normal in its starting routine and noise,without actualy firing up for wot seems like two turns then all dash lites go out,all other lites go out(except indicator strangely?
As i continue turning over all stays black but the starting sound changes as if its just the starter with no petrol and definetly no firing up.. then a weird "BONG" SOUND OCCURS (like the first part of one of those door bells?)-not a sound like any ive heard on car or alarm before?and all seems dead until i release key and it goes back to before,again and again?wots happenin?
Ive updated the syntax here and tried the bsi soft reboot which seemed to almost start her but i backed off the key/starter a second too early and then the battery was dead-swine!!!so ive re-charged my jump starter and im about to re try the soft re boot and hopefully she will start for me....i will update BUT if anyone knows the meaning of this BONG sound please let me know......thanks
R.HYDE
PostPosted: Tue Oct 16, 2012 3:12 pm Up
I gave up reading that three quarters of the way down. Paragraphs were invented for a reason!
PostPosted: Tue Oct 16, 2012 5:00 pm Up
Seriously, master the english language. Then check the crank position sensor.
bezford
PostPosted: Thu Oct 18, 2012 1:58 pm Up
Thou hast betrothed thy power oh masterly Mams Vitara and with great praise and abundant thankyou'se thine 2 of the zero six's has hastely drawn life owing equaly great reward to thine potion bearing the scipher BSI soft reboot...I have mighty wrath to bear now upon my once mighty jump starter box and as the mist of all Halfords clears i shall renew my magic box but be sure when i say that with the full force laden in me i shall smite weary box with Thors mighty hammer being sure no magic shall ever rest in thine contents hereafter ever again.....now thats English language.
R.HYDE
PostPosted: Thu Oct 18, 2012 3:55 pm Up
Try modern english....
