Online Now [190]:
Visitors: 189
Today: 36082
Total: 138826399
Forums › The Car › 206 Problems › Cooling fan not coming on
kenco
PostPosted: Tue Oct 16, 2012 2:31 pm Up
Hi, I have issues with the cooling fan. The engine is is running, the temp raises to 95 and the warning comes up on the dash and says stop. The fuses are ok. I disconnect the brown (i think) And relay energizes down near the rad, no fan operation. I disconnect the green plug and bridge it, and nothing happens. The fan is free and spins by hand. I have red posts about poor wiring to the relays is this correct ? and also a secret fuse underneath the fuse box? The car is 1.4 Petrol with air con. Does any one have any pointers
richpowell91
PostPosted: Tue Oct 16, 2012 2:45 pm Up
Check the green relays/wiring for the cooling fan in the radiator panel.
See my topic here for information:
www.206info.co.uk/Foru...29497.html
ARRAN
PostPosted: Tue Oct 16, 2012 3:54 pm Up
Relays often corrode mate, check the thread rich posted.
See my project here.
Danielpates
PostPosted: Tue Oct 16, 2012 4:35 pm Up
Yes mate check the thread but also if the fuses are ok then next is the relay and then if that's ok bell the wires out between the plugs to check for broken wires
