Latest: Beduff1977
Overall: 17134
Online Now [669]:
Visitors: 668
Today: 162913
Total: 108794969
Forums › The Car › 206 Problems › 206 with 18 ET wheels, what length bolt?
bobtabatha
PostPosted: Sat Oct 20, 2012 12:44 pm Up
Hi all
I bought a set of '206' wheel from ebay that have an offset of 18, rather than the standard 25. My question is do i need to fit longer bolts to compensate for the fact? The standard flat washer bolt thread is going 8mm into the hub.
Many thanks, mark
PostPosted: Sat Oct 20, 2012 12:50 pm Up
yes, you will need longer bolts
bobtabatha
PostPosted: Sat Oct 20, 2012 12:56 pm Up
I have looked for some on e-bay but can't see what i need as the measurements are inconsistent, any suggestions?
PostPosted: Sat Oct 20, 2012 1:00 pm Up
first you need to check if you wheels have flat seat or taper seat.
Then you will have to measure the thread length; in my memory for taper bolt you need 25mm thread and for flat seat bolt you need 32mm thread (for et25); so in your case you will need 7-10mm longer bolt
