Latest: tbafonso
Overall: 17130
Online Now [61]:
Visitors: 60
Today: 28236
Total: 104383504
Forums › The Car › 206 Problems › Big probs now!!
Big probs now!!
Go to page Previous  1, 2
NICKST
PostPosted: Fri Oct 19, 2012 4:02 pm Up
U can buy anti interruption adaptors for the hdi's I had them on my 180
karimali831
PostPosted: Fri Oct 19, 2012 5:06 pm Up
grr stalled again at 55mph on a carriageway!! not nice. Main beam on, dipped and main beam starts blinking then bang. It takes two turns to restart the engine. The ballasts are a good few inches away from ECU surely this cannot be it? It didn't act this way before, just as soon as I reach up to 60mph. Shocked
206 GTI 180
anton1989
PostPosted: Fri Oct 19, 2012 5:12 pm Up
Trade Rating: +16
remove them. see how the car drives without them? could be something other than the hids messing with the ecu
karimali831
PostPosted: Fri Oct 19, 2012 5:15 pm Up
If I remove it I won't have this problem but I am sure the problem doesn't rely on the kit itself. There is a loss of power somewhere.. I had a similar problem with the accelerator, never has done this since but see vid:
www.youtube.com/watch?...e=youtu.be
206 GTI 180
Gavin28
PostPosted: Fri Oct 19, 2012 5:18 pm Up
i would move the ballasts well away from the ECU and check you have good earths from the battery - the earth wires my need upgrading depending on the current your drawing from the electrical system.
Gav
karimali831
PostPosted: Fri Oct 19, 2012 5:26 pm Up
thanks I will check this again, these ballasts cannot go far from where the bulb is installed so there is limited options where to locate them. they are these 35w ballasts if it helps: www.ilovepopular.com/C...173-55.jpg
206 GTI 180
PostPosted: Fri Oct 19, 2012 5:52 pm Up
Have you got one near the battery or the ABS pump?
Mrs_Howey
PostPosted: Sat Oct 20, 2012 7:00 am Up
So you know all the problem are from the HID's then?! Confused Surely these problem aren't worth having the HID's fitted! Why not remove them and see how the car runs. surely the car stalling at 55mhp isn't a good idea, i'd be making the car run right.
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
karimali831
PostPosted: Sat Oct 20, 2012 12:58 pm Up
I know the HIDs make the problem worse but they can't be the source of the problem because I sometimes get random faults when something high pitched goes off. It feels like there is a bad earth point somewhere but not sure where. When I have the time I'll find out where it's coming from.
206 GTI 180
bezford
PostPosted: Tue Oct 23, 2012 9:46 am Up
the noises on the stereo sound like your speaker wires are earthing out and you might want to wire your stereo with a permanent live feed not an ignition live as this effects the sounds too.Also put a proper earth onto your stereos chassis/case ,to dampen further if the noise persists fit a surpressor
R.HYDE
karimali831
PostPosted: Tue Oct 23, 2012 5:00 pm Up
thanks I will do this.. as for the HIDs is there any way I can use them without it interfering with the ECU? No matter where I move the ballasts, it doesn't stall now but it is showing constant faults such as brake fault, ESP/ASR etc etc perhaps 50% of the time when I turn lights on.
206 GTI 180
PostPosted: Tue Oct 23, 2012 5:47 pm Up
told you before you can warp the ballast in tin foil
Page 2 of 2
