Latest: morgan20
Overall: 17135
Online Now [393]:
Visitors: 392
Today: 36081
Total: 110588246
Forums › The Car › Solved 206 Problems › Gti 180 oil leak solved
jayz206gti
PostPosted: Thu Oct 25, 2012 9:56 am Up
So id been putting off this for a few months but as an oil change was due it made sense. It was the suspect oil filter housing seal which had perrished. All in it cost me £78 which im happy with
Upgraded from 138 to 180
PostPosted: Thu Oct 25, 2012 1:06 pm Up
Was that at a dealer?!
jayz206gti
PostPosted: Thu Oct 25, 2012 1:14 pm Up
Local garage
PostPosted: Thu Oct 25, 2012 1:20 pm Up
Quite expensive for an oil change, but thats garage prices i suppose! At least you got your problem solved.
PostPosted: Thu Oct 25, 2012 2:19 pm Up
Does seem very expensive.
jayz206gti
PostPosted: Thu Oct 25, 2012 4:27 pm Up
It wasnt for just an oil change as i said in my post. The oil filter housing needed removing and the inner seal replacing
PostPosted: Thu Oct 25, 2012 4:33 pm Up
Thats very cheap
The inlet has to be removed, but the seal is only about £2 or so
