Latest: tebas93089
Overall: 17179
Online Now [83]:
Visitors: 82
Today: 35153
Total: 138453716
Forums › The Car › 206 Talk › Installing Rear LED Bulb Resistors
SteDuval1985
PostPosted: Sat Oct 27, 2012 2:09 pm Up
I want to get rid of the 'hyperflash' that occurs when using LED indicator bulbs in the rear lights.
Does anyone know which of the wires (I think there are 5) for the rear light cluster are for the indicator bulb and need to be hooked up to a load resistor?
PostPosted: Sat Oct 27, 2012 3:06 pm Up
Plexed 289 and 290
Pre plex 2337(BA) and 2347(BG)
robertmarcs
PostPosted: Sun Oct 28, 2012 10:49 am Up
www.ebay.co.uk/itm/Loa...4842c53283
just use these mate. i did, worked a treat
PostPosted: Sun Oct 28, 2012 11:45 am Up
If you went to Maplin, RS components or CPC, you could probably get 10 resistors for that price.
I use CPC quite a bit as it's only just off M6 jct 31A (behind Asda Fulwood)
