Online Now [214]:
Visitors: 213
Today: 68451
Total: 142974156
Forums › The Car › 206 Talk › Gti 180 Oil amount
Gti 180 Oil amount
DanT
PostPosted: Wed Oct 31, 2012 1:20 pm Up
Sorry if this has been covered before, i did a search on my phone but could only come up with this
www.206info.co.uk/Foru...=3238.html
Which says the 180 uses 5.3L for an oil and filter change, now i don't have the owners manual to hand so am unable to check that. When i checked autodata today before i went to order my parts it still says 4.25L even for the 180.
I'd just like to verify the correct amount if anyone knows, as the oil will be in a 5L container and i'll obviously have to get another litre if it takes 5.3 as i suspect it does!
Thanks.
PostPosted: Wed Oct 31, 2012 1:39 pm Up
according to the handbook is 3.8-5.3
so 5 is generally more than enough
ukskater01
PostPosted: Wed Oct 31, 2012 2:59 pm Up
I would put 4 in and keep topping up until I got to the max mark on the dipstick
PostPosted: Wed Oct 31, 2012 3:24 pm Up
iv found it uses more than a 5 litre can even though peugeot tell me its only 4.5 i find its nearer 5.5 litres. i always get a 5 litre and a 1 litre can then have a little bit in the 1 litre can to keep around for top ups Smile
DanT
PostPosted: Thu Nov 01, 2012 3:36 am Up
Cheers guys much appreciated, will get another litre just in case. Smile
Steve180
PostPosted: Thu Nov 01, 2012 7:21 am Up
Just like to point out that ServiceBox (which is what Peugeot use for all their data and tech) advises the EW10J4S engine requires between 4.75lts and 5.6lts, whenever I have serviced the EW10J4S, it has been AT LEAST 5.2lts, especially if you drain the system properly and fill the new oil filter slightly before fitting.
Always buy 6 litres
2004 206 GTi 180: 207.9BHP, 183.1 ft/lbs
DanT
PostPosted: Thu Nov 01, 2012 1:47 pm Up
Always buy 6 litres
I will be buying 6 litres each time by the looks of things. I havent had the car long and it was serviced just before i bought it so this is the first time i'll be doing it, and wanted to double check which was the correct information.
Thanks for the help everyone!
