Posted: Sun Sep 09, 2012 1:08 pm |
Trade Rating: +16
car- 206 1.1-non plex- y reg- no abs
had to change the caliper on my car, all the brake fluid drained out in the process, after changing i filled the car back up with fluid, bleeded all the brakes but when i press the brake pedal with the car running it hit the floor? with the car off they get a liittle hard but soon as i start the car it goes soft very soft again?
i bled it with a mate pressing the pedal
| | ![](images/spacer.gif) |
Posted: Sun Sep 09, 2012 1:14 pm |
has one of the brake cylinders gone? happened to mines the other week and had to get it replaced.. could be wrong though
Posted: Sun Sep 09, 2012 1:24 pm |
Want to borrow my ezibleed kit Anton?
Posted: Sun Sep 09, 2012 1:29 pm |
How did you bleed them?
What order did you bleed them?
Did you make sure the fluid never got low in the reservoir?
Sounds like trapped air
Posted: Sun Sep 09, 2012 1:49 pm |
Sounds like incorrect bleeding
| Team Impossible Possible
Posted: Sun Sep 09, 2012 2:08 pm |
Trade Rating: +16
anton1989 wrote: |
had to change the caliper on my car, all the brake fluid drained out in the process, |
i started with the drivers side then passengers etc
how do i get the trapped air out?
Posted: Sun Sep 09, 2012 2:13 pm |
The ezibleed kit will force it out the bleed nips. You fill a resiviour with brake fluid and with a small amount of pressure from the spare tyre it will force fluid through the lines. Opening each bleed screw (4 of them) will allow air out.
Posted: Sun Sep 09, 2012 2:17 pm |
Trade Rating: +16
cheers ![Very Happy Very Happy](images/smiles/icon_biggrin.gif)
Posted: Sun Sep 09, 2012 3:40 pm |
Do you have ABS? If you do, you might need more than Ezibleed ... air in ABS in not good ![Sad Sad](images/smiles/icon_sad.gif)
Posted: Sun Sep 09, 2012 3:50 pm |
gazza82 wrote: |
Do you have ABS? If you do, you might need more than Ezibleed ... air in ABS in not good ![Sad Sad](images/smiles/icon_sad.gif) |
![Laughing Laughing](images/smiles/icon_lol.gif)
Posted: Sun Sep 09, 2012 4:25 pm |
Trade Rating: +16
thanks seabook ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Sun Sep 09, 2012 5:20 pm |
I think it might be your mate's fault.
Posted: Mon Sep 10, 2012 3:25 am |
Trade Rating: +16
Why
Posted: Mon Sep 10, 2012 3:35 am |
if your mate press the pedal too hard it will damage the seal
Posted: Mon Sep 10, 2012 7:14 am |
Trade Rating: +16
Which seal? Easy to replace? After bleeding the pedal is as it should be, but soon as start the engine the pedal hits the floor nearly. The brakes work just have to push my foot all the way down
