Online Now [62]:
Visitors: 61
Today: 1264
Total: 105043623
Forums › The Car › 206 Problems › Shaking/judder at 40-50mph...
josho
PostPosted: Sun Nov 04, 2012 11:01 am Up
Hi there, just recently purchased an X plate HDi 2.0 with 98k. Just recently noticed sometimes the car will judder/shake quite bad at 40-50mph in 5th gear. Quite bad at times. Tried searching the forums for a few ideas on what it could be and I've put it down to maybe unbalanced wheels, wheel bearings, engine mounts, clutch judder? Although clutch feels and operates fine. Any ideas people?
PostPosted: Sun Nov 04, 2012 11:14 am Up
More than likely wheels out of balance, but i would check all suspension components.
DanT
PostPosted: Sun Nov 04, 2012 11:56 am Up
As you mentioned, wheel balancing would be the first thing to check.
Is it only in 5th? Or does it still shake at 40-50 in say 4th gear?
iSamTz
PostPosted: Sun Nov 04, 2012 1:30 pm Up
Trade Rating: -1
Could also be suspension?, friend has a similar problem, was in 3rd 4th and 5th doing the same sort of speed... the suspension was knackered.
Sam
206 1.4 2002 - Project Car
BMW 116 2012 - Work car
Yamaha R1 - Race bike (snetterton, Cadwell)
PostPosted: Wed Nov 07, 2012 12:00 pm Up
Don't know the diesels that well but is 40 - 50mph too slow for 5th gear? Is it just the engine juddering due to revs to low or too much throttle applied at that rpm?
If it is wheel balance it will always do it at the same speed. Not just sometimes.
PostPosted: Wed Nov 07, 2012 12:02 pm Up
50 is alright; 40 will be struggled
josho
PostPosted: Tue Dec 04, 2012 1:15 pm Up
Still havent had chance to diagnose this shaking, but my mechanic friend has been in it several times and mentioned that it may be a driveshaft having play? It seems to be getting worse, it starting to shake on the motorways at 70mph. Could this be true? And if so, big job?
Sim
PostPosted: Wed Dec 05, 2012 7:21 am Up
I had shaking at high speed braking due to buckled wheel hub->wheel wobble (search on this forum)
If driveshaft plays, new one costs £~80. If you can replace brake disks yourself (have tools), should be no problem to DIY shaft replacement altogether.
Otherwise labour should not be too much higher than disk replacement.
But if play comes from within tranny, things might look gloomier.
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
bezford
PostPosted: Wed Dec 05, 2012 8:37 am Up
Check wheels for dents and balancing...
Check tyres for eggs n blebs...
Are discs warped?..
Try these first
R.HYDE
josho
PostPosted: Sat Jan 05, 2013 3:27 am Up
Right checked all those things and everything ok. So does this point to a driveshaft? Or maybe engine mounts? I don't have the facilities eg. ramp to check these. Need it sorting soon, its beginning to bug me and dont fancy it breaking haha!
sheerness
PostPosted: Sat Jan 05, 2013 3:39 am Up
hi there
I have the same issue with my W-Reg, firstly I was told it was a gearbox issue, so I have that replaced, the car come back and the problem is still there, now they tell me its a drive shaft issue, awaiting a part, I think you have the same issue as mine so it a drivshaft issue,
Hope this helps
Dom......
josho
PostPosted: Thu Jan 10, 2013 3:54 pm Up
I dont think it will be gearbox as it seems to operate fine, although it does whine when im downshifting and letting it coast but once clutch is in the whine goes. Maybe this is driveshaft issue or maybe a whiney diff. Let me know if yours is a driveshaft mate it may point me in the right direction Smile
sheerness
PostPosted: Thu Jan 10, 2013 4:17 pm Up
will do.
I have yet another order of another driveshaft (keep Getting the wrong ones grrrr)
hopefully get it fitted sometime next week,
Will keep you posted.
Dom.....
josho
PostPosted: Sun Mar 03, 2013 4:59 pm Up
Ok well just thought Id shed a bit of light on this situation in case anybody else is experiencing the same.
I eventually discovered it was in fact the nearside rear wheel wobbling at speed, which was caused by knackered rear axle bearings! There was a lot of movement in the rear arm, so priced up a bearing kit and got the new bearings fitted by my self. It was actually fairly straight forward to do, got the car on axle stands and had a crack. Was expecting it to be a pain in the backside. I watched a 3 part video of a guy on youtube and found that to be a great guy. Very glad I didnt go down the whole replacing the axle route. The other side seems fine for the minute. It was also good to see there was little wear on the stub axle. Very pleased with the result, feels like a whole different car!
