Latest: tbafonso
Overall: 17130
Online Now [555]:
Visitors: 554
Today: 56858
Total: 102632776
Forums › The Car › 206 Talk › How to remove ECU from 206
chrisb1357
PostPosted: Mon Nov 05, 2012 4:49 pm Up
Hi all,
I am trying to find out how i can remove the ECU from my dads 206. We have got the front bolt off and the front part of the ECU seems to move free but the rear bolt we are unable to get to as the tight space
Any tips on how to get this off so we can check the earth cable under it
Chris
Chris
PostPosted: Mon Nov 05, 2012 6:26 pm Up
V9977 wrote:
There is a single nut at the front which holds-down the whole plate
ECU bolts onto that with another two nuts).
Undo that and the whole plate slides-out with the relay unit mounted underneath.
I would remove-reinsert the ECU connector(s) but don't use contact spray on there.
Careful when removing as the have a dual locking system with a 'finger'-key as well as the big lever 'bracket' around the connector.
The relay underneath has a Bosch type locking-connector,
unplug it and put some contact-spray on the pins, but not WD40.
There is usually another thinner (yellow?) cable mounted on the gearbox near the main earth-strap from the battery, that is the ECU earth.
Also check the +ve connection which goes to the fusebox on the right.
It should be firmly bolted and with no rot, battery and fusebox-end.
