Online Now [228]:
Visitors: 228
Today: 2179
Total: 143128696
Forums › The Car › 206 Talk › pictures of induction kit on 180
Danielpates
PostPosted: Sun Nov 04, 2012 10:47 am Up
Have baught a piper cross filter but want to see how people have fitted one on thete 180
stuy180
PostPosted: Sun Nov 04, 2012 11:46 am Up
Danielpates
PostPosted: Sun Nov 04, 2012 4:22 pm Up
Did you have that pipe custom made
alex2016g
PostPosted: Tue Nov 06, 2012 5:48 am Up
ohh wow, your engine looks so nice. Does that gti plate gets hot at all?
206 1.6 HDi 110 sport3
JamieM
PostPosted: Tue Nov 06, 2012 5:53 am Up
Yes it's custom, you can buy a few kits search bruvaaaaaaa.
I has one fitted to mine but cba to be an ASW today and grab you a pic ha.
Aegean Blue 206 GTi180
RMS-GTI
PostPosted: Tue Nov 06, 2012 6:47 am Up
I've got a pipercross on the 180 ill post a pic a bit later
Black 03 GTI. Silver 05 GTI 180
RMS-GTI
PostPosted: Tue Nov 06, 2012 6:50 am Up
Ideally though, you need to mount it somewhere where it is shielded as much as possible. I got a KandN 57 gen II. Put it on without the air box, and it suffered really badly from heat soak and it ran really badly. I then fitted the KandN heat shield and I connected the standard air fed to the hole in the bottom of the box with a length of flexi tube, difference was night and day in terms of how the car ran and performed. Simply because it didn't get anywhere near as hot and it had a good supply of cold air
JamieM
PostPosted: Tue Nov 06, 2012 8:34 am Up
Ok I'll drop mine in;
Simota CAIS - Basically the same as a BMC CDA.
