![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › bsi's soft and hard boots |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Fri Nov 09, 2012 3:28 pm |
Iknow that,thanks to 206info it is quite easy to perform a bsi soft reboot on my 206gti,2002model and probably all other 206's,but.....is it possible to perform a bsi hard reboot on your own vehicle?i have heard some references about the need for cars needing a hard reboot but i would like to know if anyone knows if its possible?
Would they share the method/instructions on how to perform the hard reboot at home without loads of workshop tools and peugeot experience.???Maybe someone can make a sticky about soft and hard reboots on the beloved 206 pugs.Also some details regarding when the use of a hard reboot would be advantageous and what this hard reboot should overcome and achieve?and why/when to use it???cheers.
| | ![](images/spacer.gif) |
Posted: Fri Nov 09, 2012 3:35 pm |
I think it's the same; soft-boot, re-boot, reset, hard-boot etc.
It's for mux 206 (2002 onwards) only.
| ![](themes/base/images/forums/otr.gif) |
