Posted: Sat Nov 10, 2012 1:46 pm |
so i tried to change the rong speedo form a newer car with the engin running im such an idiot but now the car stereo wont display anything but it will take a cd and when i push the eject button it ejects i was wondering if anyone could help me it would be greatly apreciated
Posted: Sat Nov 10, 2012 1:47 pm |
have you checked the fuse's below the steering wheel ?
Posted: Sat Nov 10, 2012 1:51 pm |
What do you mean exactly by wrong-speedo. Where the plugs behind the unit the same?
If you have a factory fitted stereo and you are refering to the MFD (not actually ON the headunit but in the centre section on the car) not displaying stereo info, sounds like you've messed-up the CAN bus by pluging with engine running. Try reseting the BSI.
Posted: Sat Nov 10, 2012 2:41 pm |
ok thank you very much i will try reseting it tomorrow and its an after market stereo and the plugs were rong i just wanted to see if it would work and i did check the fuses
Posted: Sat Nov 10, 2012 2:59 pm |
stoisha wrote: |
ok thank you very much i will try reseting it tomorrow and its an after market stereo and the plugs were rong i just wanted to see if it would work and i did check the fuses |
If the plugs where wrong it wouldn't work.
I don't think BSI reset would help in this case if the stereo is playing up and is not factory fitted. Worth a try though and check the fuse on the back of the stereo itself just incase.
Posted: Sat Nov 10, 2012 3:43 pm |
So many problems seem to be caused by aftermarket stereos.
Can't decide if it's the crappy French car that they are being fitted into, or if it's user error. I am tending to lean towards the latter.
Posted: Sat Nov 10, 2012 4:09 pm |
its not the fuse its fine i dont no what to do but im still going to do the bsi reset tommorow and see what happens because ive been having problems since i had the car and its doing my head in maybe this will help MAYBE ~?
Posted: Sat Nov 10, 2012 4:36 pm |
Trade Rating: +16
Sounds like you've fried the bsi and now its lost signals from your dash board connections.
Take it to have its codes read and see what comes up, that will also give you some idea about the previous problems.
Posted: Sat Nov 10, 2012 5:39 pm |
ok
Posted: Sat Nov 10, 2012 6:18 pm |
u no the bsi reset procedure is it the same for pre-plexed as it would be for multi plexd
Posted: Sat Nov 10, 2012 6:21 pm |
I believe BSI reset is only for multiplexed (built Nov 2001 onwards).
Posted: Sat Nov 10, 2012 7:12 pm |
oh ok so what can i do then
Posted: Sun Nov 11, 2012 3:50 am |
Check all fuses again, (engine fusebox, cabin fuse box and back of the headunit itself) with multimeter not just visualy.
Make sure you didn't disturb any wiring when you were messing with the clusters.
I can't see the BSI affecting the stereo though on a non-mux car. Possibly a wiring issue..
Posted: Sun Nov 11, 2012 7:50 am |
Taken from the thread
HOW TO: Soft boot the bsi and change battery
Lee wrote: |
For a non-multiplexed model
- You may need your radio code upon reconnection
- If your car has a Peugeot anti-theft alarm system, disable this
- Disconnect the negative terminal first
- Disconnect the positive terminal
- Complete intentions
- Now to re-connect, Connect the positive terminal first
- Connect the negative terminal
- Before starting the engine for the first time, turn on the ignition and wait for 10 seconds to initialise the various electronic control units
- Activate alarm system, if you have one |
Posted: Sun Nov 11, 2012 9:30 am |
thank you ver much ive been having electrica problems since i got it
