Latest: Beduff1977
Overall: 17134
Online Now [1427]:
Visitors: 1426
Today: 199033
Total: 109765457
Forums › The Car › 206 Talk › GTI oil consumption
GTI oil consumption
RMS-GTI
PostPosted: Fri Nov 02, 2012 4:04 am Up
Sorry if this has been covered, but how much is acceptable? I remember my old GTI using a fair bit but I can't remember how much. I haven't measured this properly but I think I've used about 1 litre in just over 3k.
Car either gets used on the two mile drive to work, or hundreds of miles on the motorway in one go for football.
Any opinions?
Black 03 GTI. Silver 05 GTI 180
nellyhaggis
PostPosted: Fri Nov 02, 2012 6:33 am Up
Mine used a bit more than that.
What oil are you putting in?
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Fri Nov 02, 2012 7:05 am Up
Doesnt sound too bad.
PostPosted: Fri Nov 02, 2012 10:12 am Up
180gti is a oil burner
RMS-GTI
PostPosted: Fri Nov 02, 2012 6:40 pm Up
5w40 semi synth
crocdino
PostPosted: Fri Nov 09, 2012 12:48 pm Up
Mine uses about a litre in 8000 miles.
5/40 fully synth
GTI 138 facelift - Runabout
335d M Sport - Cruiser
crocdino
PostPosted: Fri Nov 09, 2012 12:49 pm Up
Infact scrap that, about half that.
I bought 5 litres to do the change. Used 4.5 on the change and used the rest over the year to top it up. Did about 8k in the year.
usher
PostPosted: Fri Nov 09, 2012 12:54 pm Up
mine dont use enough to warrent filling up before the next service think i do 6k a year max atm
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
bisphenol-a
PostPosted: Tue Nov 13, 2012 5:46 am Up
what happens if you let the car run with low oil? would the temperature gauge show an increase in engine temperature?
rick-gti
PostPosted: Tue Nov 13, 2012 5:49 am Up
It will probably start to knock rattle if it gets to low. Oil lubricates, water cools.
clio 197sport owner
