Online Now [307]:
Visitors: 306
Today: 63958
Total: 106041046
Forums › The Car › 206 Problems › Help needed multiple parts
Sk3rry93
PostPosted: Tue Nov 06, 2012 5:11 am Up
Ok so i know whats wrong with the car and ive spoke to peugeot about getting these parts what im after is,
Lambda sensor, engine mount, abs ring and a 180 gti arb, but peugeot is looking insane money, anybody got any other ideas on where to look? and if anybody knows anything on the prices of the 180 arb, itd be much appreciated
iainlovatt
PostPosted: Tue Nov 06, 2012 5:16 am Up
New ,, Reconditioned?
Eurocarparts is always a winner. Very Happy
(My Garage)
Sk3rry93
PostPosted: Tue Nov 06, 2012 5:30 am Up
well ive tried europarts, they dont have an abs ring it looks like itl be a full dshaft, might try the breakers for that, they want mad money for a universial lambda sensor, didnt check the engine mount as i can it local for £20 anyways
sicskate
PostPosted: Tue Nov 06, 2012 5:40 am Up
Trade Rating: +13
Eurocarparts usually have either a 25% or 30% off deal on the go Smile
307 1.4hdi Smile
PostPosted: Tue Nov 06, 2012 6:08 am Up
What engine have you got?
Sk3rry93
PostPosted: Tue Nov 06, 2012 10:06 am Up
Yeah i think i noticed 30% earlier Very Happy TU1JP
dan.brown.120393
PostPosted: Tue Nov 13, 2012 10:00 am Up
If It helps I know motor factors/dealers only sell the whole drive shaft. Had to replace the whole drive shaft on my sisters car due to the cv joint failing.
Dan Brown
Razor34
PostPosted: Tue Nov 13, 2012 10:45 am Up
GSF Car Parts are normally pretty good
Ray
PostPosted: Tue Nov 13, 2012 11:40 am Up
I got a driveshaft from Euro Car Parts. It was 2/3rds as thick as the original. So it got returned. Got an exchange shaft from Peugeot.
