Posted: Tue Oct 16, 2012 8:08 am |
How do you know if the rear axle bearings are failing?
What are the symptoms?
Posted: Tue Oct 16, 2012 8:47 am |
I think a bit of camber is one symptom and also if the wheel doest sit central to the arch?
Im sure there are other symptoms aswell.
Posted: Tue Oct 16, 2012 10:10 am |
squeeking over bumps for the trailing arm bearings
Posted: Fri Nov 16, 2012 4:45 am |
And the rear suspension will getting much more stiffer.
Posted: Fri Nov 16, 2012 8:36 am |
When parked pull on the rear wheels to see if there is play
| You never really learn to swear until you learn to drive | |
