Latest: tebas93089
Overall: 17179
Online Now [122]:
Visitors: 122
Today: 1639
Total: 138475514
Forums › The Car › 206 Problems › HELP needed asap please!
anton1989
PostPosted: Sun Nov 18, 2012 9:42 am Up
Trade Rating: +16
in the middle of fitting my fmic and can not work out which wat the black pipe from the 406 goes???
i no which end goes to the turbo i just dont know how its ment to sit???
can anyone help???
PostPosted: Sun Nov 18, 2012 9:48 am Up
Have you cut the inch or two off the end?
anton1989
PostPosted: Sun Nov 18, 2012 10:05 am Up
Trade Rating: +16
no mate should i? which end?
anton1989
PostPosted: Sun Nov 18, 2012 10:11 am Up
Trade Rating: +16
[IMG]http://i1064.photobucket.com/albums/u368/antonhall1989/DSC00492.jpg[/IMG
This is how it is so far. I cant get the pipe to sit in the hose all the way?
PostPosted: Sun Nov 18, 2012 10:21 am Up
It should sit on squarer than that.
anton1989
PostPosted: Sun Nov 18, 2012 10:45 am Up
Trade Rating: +16
cant get it to for s**t
PostPosted: Sun Nov 18, 2012 11:33 am Up
make sure there is nothing in the way
bezford
PostPosted: Mon Nov 19, 2012 7:07 am Up
The bottom shorter pipe should be longer so your not fouling the course of the longer pipe.
R.HYDE
anton1989
PostPosted: Mon Nov 19, 2012 8:10 am Up
Trade Rating: +16
Cn you exsplain bit more please?
bezford
PostPosted: Mon Nov 19, 2012 12:35 pm Up
It looks to me that if the short bottom pipe with the two white stains on each end was just under two inches lomger then the long pipe with the right angle at the end would sit into the shorter pipe much better making the join snug fitting.
R.HYDE
anton1989
PostPosted: Mon Nov 19, 2012 12:52 pm Up
Trade Rating: +16
i see, no them pipes are not the problem i can move them
bezford
PostPosted: Sun Nov 25, 2012 7:29 pm Up
the thick clean black plastic piping you mean?like 3inches wide and 8/9inches around the cicumference?there the only ones with a problem as far as i caN SEE?
R.HYDE
