Latest: tbafonso
Overall: 17130
Online Now [378]:
Visitors: 377
Today: 8032
Total: 104539870
Forums › The Car › 206 Problems › Engine change
Engine change
Go to page Previous  1, 2, 3
sean.r.steward
PostPosted: Fri Nov 23, 2012 8:59 pm Up
t16 it
Deano
PostPosted: Sat Nov 24, 2012 4:20 am Up
What's t16
PostPosted: Sat Nov 24, 2012 5:18 am Up
A rare engine made in such small number it's largely irrelevant.
Deano
PostPosted: Sat Nov 24, 2012 6:20 am Up
Guess I will just stick with the 2.0 then
Deano
PostPosted: Mon Nov 26, 2012 6:25 am Up
Does any one know the answer to my question then does the fly wheel have th go onto the donor engine or is it not the same on these
Deano
PostPosted: Mon Nov 26, 2012 6:32 am Up
All the flywheels are the same...
Deano
PostPosted: Mon Nov 26, 2012 6:36 am Up
Thank you it just I changed one on a river as I said above and I had to take it apart to change flywheel because the fly wheel had to stay with ecu dodhh
Page 3 of 3
