Posted: Wed Nov 21, 2012 2:48 pm |
Just purchased an OBD Bluetooth adaptor which gets info from your ECU to your Android phone anything up to Turbo, Boost, G force etc fuel usage and Fault lists dont know if any of you guys have ever used one if not will let you know how it goes and works
Source torque-bhp.com/
Posted: Wed Nov 21, 2012 2:51 pm |
i wonder what data you could see over the software as most of these OBD gauge doesn't work too well in a 206
Posted: Wed Nov 21, 2012 2:54 pm |
Hmm seen one guy on youtube plugging one in and using it hopefully a few instruments and data come up more or so the fault codes
Posted: Wed Nov 21, 2012 3:17 pm |
Mine doesnt have an OBD anymore
| Team Impossible Possible
Posted: Wed Nov 21, 2012 3:37 pm |
NayNay1991x
I Look forward to hear if it's any good. How much was it ?
PP2000 seems to be the most common OBD system. It's a very complex system too from my understanding.
Posted: Wed Nov 21, 2012 3:38 pm |
I was going to get one but unsure what it shows via the OBD. Can you tell us what it shows when used with your 206?
Posted: Wed Nov 21, 2012 3:47 pm |
| perrygraf wrote: |
NayNay1991x
PP2000 seems to be the most common OBD system. It's a very complex system too from my understanding. |
Childs toy, try flash code reading, now thats hard
Posted: Wed Nov 21, 2012 4:04 pm |
| perrygraf wrote: |
NayNay1991x
PP2000 won't work with a generic EOBD connector. You need a specific Peugeot lead so that your computer will communicate with the car.
Posted: Wed Nov 21, 2012 4:11 pm |
Correct
Posted: Wed Nov 21, 2012 4:59 pm |
Definetly let you guys know hopefully i receive it tommorow if not friday will keep you updated the adaptor only cost £8.99 on ebay
Posted: Thu Nov 22, 2012 9:15 am |
What did The actual unit cost you then?are they cheap enuf to have a punt?
Posted: Thu Nov 22, 2012 1:33 pm |
elm327 can show me, appart from errors, it show me up to 18 variable (lambda sensor, rpm, coolant temp, load, ERG,... can't remember more)
its not massive info, but can be useful for just some bucks
Posted: Thu Nov 22, 2012 5:03 pm |
Posted: Sat Nov 24, 2012 8:22 am |
works amazing in the VXR. Boost, temps etc. Brilliant device. Some people on VXRonline who don't want to go plumbing in gauges have actually had a centre console built to fit an android tablet to show all the information. As the VXR doesn't have a boost gauge or temp gauge as standard for some mad reason.
Posted: Sun Nov 25, 2012 10:29 am |
Unfortunately my Peugeot 206 (1999) can't seem to find or wont talk with the ECU had a look around some forums only to hear that cars later than the Year 2000 are OBDII compliant unless I'm doing something wrong then maybe someone could tell me, The device lights up perfect, lights flickering but doesn't seem to be talking to my ECU. However I do know that this does work with 206's.
Sorry guys
