Latest: Worthy967
Overall: 17143
Online Now [544]:
Visitors: 542
Members: 1
Today: 34390
Total: 114610720
Forums › The Car › 206 Problems › Upper grille front badge
Tolkienfan001
PostPosted: Thu Jan 03, 2013 1:31 pm Up
Trade Rating: +13
So, I have just bought a second hand badge as above as I want to spray the lion and chrome surround.
As I don't want to break it what is the correct way to separate the Chrome parts from the black backing part of the badge?
Thank you in advance for your help.
2005 1.4 16v Sport
Check out my 206 here!
Nic_206
PostPosted: Thu Jan 03, 2013 1:39 pm Up
there's clips on the back just a case of being patient and gentle
Ford focus st3 daily driver
Team: Red 20v6
Tolkienfan001
PostPosted: Thu Jan 03, 2013 1:41 pm Up
Trade Rating: +13
What tool if any should I use. Do I just push the clips?
Also just checking is plastic primer ok to use?
2005 1.4 16v Sport
PostPosted: Thu Jan 03, 2013 4:11 pm Up
you need to gently push the tags apart behind and pull it off a bit at a time be careful of the tail on the lion though as that pushes in tight and is very easy to break off!!
Tolkienfan001
PostPosted: Thu Jan 03, 2013 4:52 pm Up
Trade Rating: +13
Got it all off. Broke two pins doh! Glued them and seem fine now.
Can someone please confirm I can treat them as normal car plastics.
Key(sand) surface.
Wash
Dry
Paint prep wipes
Plastic primer
Wet sand
Colour
Wet sand
Lacquer
Cut and polish
2005 1.4 16v Sport
QuArTz
PostPosted: Thu Jan 03, 2013 5:11 pm Up
Trade Rating: +16
What colour are you going to spray it?
I have a Red, Black and White set, if your interested...:D
Tolkienfan001
PostPosted: Thu Jan 03, 2013 5:14 pm Up
Trade Rating: +13
Red. To match the red bonnet vent, mud flaps calipers etc. thinking a red 206info sticker for the boot as well.
Thanks for the offer but I am enjoying doing the work to doe o the parts. Smile
2005 1.4 16v Sport
QuArTz
PostPosted: Thu Jan 03, 2013 5:58 pm Up
Trade Rating: +16
No worries.. Thats the reason I have three differant colours Very Happy
Go to your local scrappy and get a couple of sets, firstly to see how they are attached to the grill and secondly to practice spraying on.
Tolkienfan001
PostPosted: Fri Jan 04, 2013 1:19 am Up
Trade Rating: +13
I am happy with spraying I have already done the bonnet vent. Just not sure if it's plastic primer I need?
2005 1.4 16v Sport
