Posted: Thu Nov 22, 2012 2:44 pm |
I don't know if anyone can help i have a set of morette lights fitted to my 206 and it passed the mot but now the nights have pulled in the lights are so bad it's like they are not on i didn't know if you can adjust them as when you look at the lights the optics are showing what looks like metal on the inner edge and I think they need adjusting from left to right not up and down any help would be great full
Posted: Thu Nov 22, 2012 2:45 pm |
Don't think you can adjust morettes, if so I diddnt know you can
I have the same problem I cannot see more than like 1 metre ahead, I purchased some HIDs which have helped very slightly ...
Posted: Thu Nov 22, 2012 2:50 pm |
How much are the kits as I have seen them on eBay starting from £18 but don't know how easy they are to fit
Posted: Thu Nov 22, 2012 2:55 pm |
Well when buying HIDs you need to know the legalities before purchasing anything
You can find some info in the non legal section as to which ones you can't have. Also if you use the search bar I'm sure you'll find what you need to know
Posted: Thu Nov 22, 2012 2:58 pm |
I know it's all down on how bright they are it will be 6k or 8k are the ones I'm looking at
Posted: Thu Nov 22, 2012 3:04 pm |
i had morettes on mine and i could see fine with some osram nightbreakers :/
| Ford Focus RS in white of course
filled with all sorts of goodies | |
Posted: Thu Nov 22, 2012 3:10 pm |
I think that what i have in there £12 off amazon
Posted: Thu Nov 22, 2012 3:22 pm |
there are some plastic things on them which you can use a philips screwdriver with to adjust the angle (left,right, up, down)
Posted: Thu Nov 22, 2012 3:50 pm |
I can only see 1 on each side
Posted: Thu Nov 22, 2012 4:21 pm |
Posted: Thu Nov 22, 2012 4:55 pm |
Ok I will give it a try Saturday in the day light
