Latest: lio94
Overall: 17181
Online Now [214]:
Visitors: 213
Today: 52277
Total: 142002800
Forums › The Car › 206 Problems › Rear axle
Rear axle
Boywonder7
PostPosted: Sat Nov 24, 2012 12:38 pm Up
Need help.. Rear axle on my 1.1 is knackered .. I bought the bearing repair kit from Peugeot fitted it this morning but the shaft on the beam where the bearings sit on is the problem I seen a kit on eBay that includes a replacement shaft. Does anybody know how to change the shaft on the beam?
Would appreciate some help guys
Boy Wonder
PostPosted: Sat Nov 24, 2012 12:45 pm Up
you need proper tools to do it.
normal garage or even dealer will not be able to do this.
Boywonder7
PostPosted: Sat Nov 24, 2012 12:49 pm Up
What tools? And who would do it for me then?
Boy Wonder
PostPosted: Sat Nov 24, 2012 12:51 pm Up
Recon rear axle with a warranty is always the way to go with these.
Unless you have access to the correct tooling for repairing a worn axle there just not worth bothering with.
PostPosted: Sat Nov 24, 2012 12:55 pm Up
proper big size hydraulic puller and press.
The cross membrane arm will be pulled out together with the stud.
so forget to rebuild it yourself, it is impossible.
PostPosted: Sat Nov 24, 2012 12:57 pm Up
We have both at work Whistle...
Don't get used that often but there both handy bits of kit to have in a workshop Laughing
Boywonder7
PostPosted: Sat Nov 24, 2012 12:58 pm Up
Oh s**t ok was worth asking the question cheers lads
Boy Wonder
Razz
so you can do him a favor then Laughing Laughing Laughing Laughing
PostPosted: Sat Nov 24, 2012 1:01 pm Up
Razz
No chance, I wouldn't even bother rebuilding my own let alone somebody elses Laughing
If it was my own car i'd just order up a recon beam & fit that instead.
Boywonder7
PostPosted: Sat Nov 24, 2012 1:09 pm Up
Haha worth a try sea book. I'm just gonna get a recon one off the web much easier less hassle
Boy Wonder
iainlovatt
PostPosted: Sat Nov 24, 2012 4:46 pm Up
Get a second hand axle job done!!
(My Garage)
Lecktorious
PostPosted: Sat Nov 24, 2012 5:33 pm Up
Trade Rating: +59
False economy.
'98 Nile Blue 306 GTi 6
LORDPSK
PostPosted: Sun Nov 25, 2012 9:50 am Up
Secondhand axle will cost between £80 & £100 non abs normal drums, reconditioned £250. All plus delivery, depends on age of car, how long you want to keep it and if you have the money for a recon. I fitted a secondhand and two months later the bearings went again, lucky it was covered by a 3 month warranty.
Peugeot 206
