Latest: Beduff1977
Overall: 17134
Online Now [450]:
Visitors: 449
Today: 58713
Total: 109229591
Forums › The Car › 206 Problems › A/C only blows cold air
Ciucur
PostPosted: Sat Nov 24, 2012 9:45 am Up
I searched the forum and google for a solution to my problem but found none so here it is.
Last night after listening to music for quite some time (engine off) I started up the car, it barely started after making that distinct sound as if the battery was flat. I need to change the battery pretty soon, but that's not the problem.
The A/C was on 28 degrees but it started blowing only COLD air. It did this a while back, but it came to its senses in like 2 days without me doing anything to it.
So far I tried:
Opening the coolant cap and letting the engine run for 5-10 mins while reving it
I tried bleeding the coolant system by unscrewing the little brass screw on the thermostat housing
It's a 1.4 if that makes any difference.
I need help ASAP please! Embarassed
Thanks, Chris.
lmilligan
PostPosted: Sat Nov 24, 2012 12:36 pm Up
A/C is air conditioning? It's supposed to be cold. Turn a/c off and then you'll have hot air coming through.
PostPosted: Sat Nov 24, 2012 12:41 pm Up
Rolling Eyes
AC works for all temperature's, it doesn't just make the air colder Wink
lmilligan
PostPosted: Sat Nov 24, 2012 4:32 pm Up
MrBSI wrote:
Rolling Eyes
alright just never heard anyone say oh it's cold let whack the ac on full blast Rolling Eyes
Ciucur
PostPosted: Sat Nov 24, 2012 6:22 pm Up
OK, I'll rephrase it...
Heating doesn't work, I tried turning it off, on, I changed the temp to cold back to hot, I changed to "eco" back to A/C...nothing works.
1.4 16v Black
anton1989
PostPosted: Sat Nov 24, 2012 7:15 pm Up
Trade Rating: +16
blower may be broke? just so happens i have on for sale Very Happy
£30
PostPosted: Sun Nov 25, 2012 3:15 am Up
Can you feel warm pipes under the dashboard?
Ciucur
PostPosted: Sun Nov 25, 2012 4:10 am Up
£30
If the blower were to be broken wouldn't it stop blowing any air? It still works but only with cold air.
Nope, I can't say that I do.
1.4 16v Black
PostPosted: Sun Nov 25, 2012 5:24 am Up
lmilligan wrote:
MrBSI wrote:
Rolling Eyes
You just don't understand how ac really works Wink
Ciucur
PostPosted: Sun Nov 25, 2012 1:23 pm Up
It was a simple electrical fault behind the A/C display. It's now fixed. Smile
1.4 16v Black
