Latest: tebas93089
Overall: 17179
Online Now [106]:
Visitors: 105
Today: 33444
Total: 138180340
Forums › The Car › 206 Problems › Knocking/rumbling noise
JackRadd
PostPosted: Thu Nov 29, 2012 2:57 pm Up
Hello, slight issue with my car which has a few different garages baffled. Wondering if anyone has experienced similiar to me.
When turning the wheel to the left when driving anywhere from 10mph upwards a rumble noise comes from the front left wheel?
Had it off and had a good look around but can't see anything out of the ordinary
Cheers
Jack
nellyhaggis
PostPosted: Thu Nov 29, 2012 3:38 pm Up
Wheel bearing, sticking pad?
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Thu Nov 29, 2012 4:28 pm Up
CV joint,wheel bearing or top mount.
PostPosted: Thu Nov 29, 2012 4:50 pm Up
I doubt it'll be the wheel bearing if the noise is coming from the left.
Deano
PostPosted: Fri Nov 30, 2012 9:30 am Up
It will most probaly be the cv joint mate
bezford
PostPosted: Fri Nov 30, 2012 6:51 pm Up
Had new alloys/tyres lately???or made any changes/fittings at all lately???
R.HYDE
lukecalderon
PostPosted: Sun Dec 02, 2012 1:06 pm Up
I literally just had the problem occur - I was turning into a side street, fully locked to the left, and had a knocking noise come from the front-left wheel. I tried it again when turning into my drive and it happened again.
Have you got anywhere with the problem?
LORDPSK
PostPosted: Sun Dec 02, 2012 3:00 pm Up
I would go with the CV joint, sounds the same as mine used to be, its the easiest of the two drive shafts to change
PostPosted: Sun Dec 02, 2012 3:51 pm Up
Yep, CV joint.
lukecalderon
PostPosted: Sun Dec 02, 2012 5:09 pm Up
Is it expensive/difficult to replace a CV joint on a 206?
DougalR
PostPosted: Sun Dec 02, 2012 7:32 pm Up
I pretty sure you have to replace the drive shaft, its about and hour job at a garage. you have to refill the gearbox with fluid after its poured out from removing the shaft. maybe a good idea to do the seal too in the diff.
You can only plan so far, after that you have to take a few leaps of faith.
2001 206 GTi - Daily
2003 VW Golf .:R32 - toy
2001 106 Gti - in pieces.....
swaynie
PostPosted: Sun Dec 02, 2012 8:11 pm Up
the knock on lock can also be the top mount
If your offended by my posts call\r\n0800 I dont care Wink
bezford
PostPosted: Tue Dec 04, 2012 9:27 am Up
If u fancy doing it yourself get a complete shaft from a scrappy...it works out cheaper than doing the joint alone...check it for play when u buy it...they should have decent ones already off the cars...also buy a ball joint seperator for about £9 to save lots of time...the tool shop should tell u how to use it...if its not obdvious...
R.HYDE
