Latest: jackrox1992
Overall: 17186
Online Now [339]:
Visitors: 338
Today: 241289
Total: 148376522
Forums › The Car › 206 Talk › What would happen if i ground my sills off?
Forum Index › 206 Talk
pnut_man
PostPosted: Mon Dec 03, 2012 10:40 am Up
are they important? and if i couldnt grind the whole thing off maby half?
Lowered my car at the weekend and its only 1inch of the ground all round, need to loose the sills as my coilovers have seized up and i cant raise it up.
+++ Help not hinder please +++
Rob2859
PostPosted: Mon Dec 03, 2012 11:09 am Up
You would not be able to jack the car up from the side.
pnut_man
PostPosted: Mon Dec 03, 2012 11:12 am Up
well if i left a small bit of the sill still in place for jacking, each side? what are they for anyways? just jacking??
Rob2859
PostPosted: Mon Dec 03, 2012 11:26 am Up
It would probably just squash anyway. a normal jack bends the sills anyway unless its got a huge base plate. I don't know why Peugeot even recommend jacking it there.
I would get a second opinion before you go ahead but I doubt they are structurally integral. I have bashed and squashed mine to hell and its not split in half.
pnut_man
PostPosted: Mon Dec 03, 2012 11:52 am Up
yeah mine are pretty battered too. was thinking of cutting them off because it will be cleaner than bending them, but yeah, all i really need to know for sure is if they are structurally integral. if not then bye bye sills!
PostPosted: Mon Dec 03, 2012 12:39 pm Up
Thats the seam where the inner and outer sill are welded together...If you've mangled it by jacking it up there then you've not been very nice to the car.
Use a trolley jack with a 12" block of 2" thick timber between the jack head and the box sections under the floor. If your car is too low then drive up some blocks of timber to get more height.
pnut_man
PostPosted: Mon Dec 03, 2012 12:54 pm Up
Im pretty sure my car doesn't like me eddy, however i know how to jack my car up, i just need to know if the sills need to be on the car.
PostPosted: Mon Dec 03, 2012 12:56 pm Up
The sills make up part of the strength of the car. Cut them off and if you get hit by or run into something then you will increase the chance of the car folding in 2 and mangling you against the steering wheel.
Go for it, it could be entertaining.
pnut_man
PostPosted: Mon Dec 03, 2012 12:58 pm Up
No need to be bitchy macca, its just a question.
PostPosted: Mon Dec 03, 2012 1:00 pm Up
Apart from all that they aren't important.
pnut_man
PostPosted: Mon Dec 03, 2012 1:05 pm Up
cool. ill just cut em off then, no harm in a little steering wheel mangling every now and then.
Mattie-RS
PostPosted: Mon Dec 03, 2012 1:08 pm Up
Laughing
PostPosted: Mon Dec 03, 2012 2:28 pm Up
Who's making the popcorn then?
HDI90
PostPosted: Mon Dec 03, 2012 3:03 pm Up
Is this a joke?
GTI 180
pug206lx
PostPosted: Mon Dec 03, 2012 4:39 pm Up
Don't expect the car to see an MOT pass certificate again.
