Posted: Sun Dec 02, 2012 1:26 pm |
Hi all
Gf's Peugeot 206 1.6Hdi CC
1 - pulling to the left (tryes pressures are fine and so are brakes) TRE???
2 - drivers window will not go down in the cold, the shark fin (rear window) goes down when putting roof down but not front one
3 - the bracket support of the exhaust has broken off,currently in put with some tack welds but would like to replace the bracket, so far ive only found the bracket if i buy the exhaust back box complete.
Im sure more will pop up soon
cheers
Posted: Sun Dec 02, 2012 1:49 pm |
1 - check the tyre wear on both tyres, and make sure the camber on both wheels are the same. Might want to check the alignment is the same too
Posted: Tue Dec 04, 2012 8:09 am |
Do u want me to come and do it for u aswell? U need to get your hands dirty and have a look...steering could be tracking and why would they sell an exhaust bracket?how would it be fitted?its part of the box for a reason..
As for the window...av a look.
Posted: Mon Dec 17, 2012 10:55 am |
useful answer cheers bez!
Another problem its developed
every time it starts it seems to "vibrate/shudder" as if the car is cold when on idle - revs are at 900-1k and goes shivers till its warmed up....normal?
Posted: Mon Dec 17, 2012 11:34 am |
Mine does this all the time as well... Probably engine mounts but ive been told its nothing major!
