Posted: Sun Dec 02, 2012 3:34 pm |
Hi everyone I have tried to search on this one first but came up with nothing I have just put new engine in my gti but they was squiling coming from down the belt side having investigated a bit more I have found out the auxillary tensioner is the problem can I change it in place or will I have to take it off mounting and move engine over like doing the belt or has anyone done this in situe ![Sad Sad](images/smiles/icon_sad.gif)
| | ![](images/spacer.gif) |
Posted: Sun Dec 02, 2012 3:38 pm |
I replaced mine quite easily. Think it was £37 from euro car parts. Couple of 13mm bolts and it comes off.
Posted: Sun Dec 02, 2012 4:20 pm |
I have the part it was still on new engine luckily it's the one where u press it back with a 17m spanner and put a Allen key or some thing in to hold it the belt was tight to get on So I tried to undo it but its left hand thread must of snapped it anyway its a torq bolt that holds it in and u can't get a socket and wratchet anywhere near it I have some torq allenkeys I will try them tomorrow if not I will probally have to lower that end of the engine
Posted: Mon Dec 03, 2012 2:19 am |
Don't go near the torx bolt. Just remove the two bolts holding it onto the engine block. It's a 16mm spanner on the bolt to lever the tenstior out of the way.
![](http://i38.photobucket.com/albums/e105/s1pso/Fylde-20121005-00191_zps3a58526c.jpg~original)
Posted: Mon Dec 03, 2012 2:34 am |
Ye that's the problem when I put the spanner on to lever it out the way the bolt is just spinning I will have a look see if I can get to the 2 bolts tonight lever it out the way some how thanks for the pic though great help
Posted: Mon Dec 03, 2012 4:44 am |
Deano wrote: |
Hi everyone I have tried to search on this one first but came up with nothing I have just put new engine in my gti but they was squiling coming from down the belt side having investigated a bit more I have found out the auxillary tensioner is the problem can I change it in place or will I have to take it off mounting and move engine over like doing the belt or has anyone done this in situe ![Sad Sad](images/smiles/icon_sad.gif) |
Did that timing belt change go OK?!
Posted: Mon Dec 03, 2012 5:41 am |
Ye spot on mate thanks engine running sweet first go just a little problem with auxcillary tensioner which I should have sorted tonight thanks for help though they not to difficult once u understand how it works
Posted: Mon Dec 03, 2012 1:35 pm |
Sorted tensioner tonight without to much trouble still a little squeak comin from down there but might run off when I start using it again get it sprayed over next few days and should be back on road by wkend
Posted: Mon Dec 03, 2012 3:51 pm |
Watch where you spray around there as V-belts don't like it very much.
Could be pulley bearing on the way out esp. if it goes when warmed-up after a while.
Posted: Mon Dec 03, 2012 5:46 pm |
I just changed tensioner on auxillary belt not brand new though on done 39 thousand I think the noise is coming from power steering pulley I snapped pipe trying to fit it and the one from scrap. Yard was cross threaded so when I started it first time powerstering fluid went every where got on belt would that make a squeak noise of power steering fluid on belt I have fixed powerstering now might need new belt though now
Posted: Tue Dec 04, 2012 9:07 am |
U will need a belt mate..try and use a bit more finnesse on these french motors mate..they aint hgv's and u seem to be havin a lot of bad luck with snaps and breaks...good luck
Posted: Tue Dec 04, 2012 9:48 am |
Ye it was the top hose with the nut and flange it was solid I wd40 it but it still snapped I will put new belt on at the wk end mate need to concentrate on spraying the wing n bumper now
