Latest: SA01
Overall: 17138
Online Now [240]:
Visitors: 239
Today: 40464
Total: 111286891
Forums › The Car › 206 Problems › Gearbox oil
Gearbox oil
Deano
PostPosted: Mon Dec 03, 2012 6:55 pm Up
How do u check gearbox oil level and how do I fill gearbox with new oil thanks for any help its much appreciated and anything I can help u with would be happy to help thanks
DeadEyePaul
PostPosted: Mon Dec 03, 2012 7:23 pm Up
Suggest you invest in one of these
Deano
PostPosted: Tue Dec 04, 2012 4:11 am Up
I will do eventually mate but I don't have time at mo I got one last job to put box oil in as I lost a bit when I took drive shaft out
PostPosted: Tue Dec 04, 2012 5:41 am Up
+1
PostPosted: Tue Dec 04, 2012 5:46 am Up
Use the fill / level plug on the gearbox, that's what it's put there for Wink
Deano
PostPosted: Tue Dec 04, 2012 6:11 am Up
Ha ha clever c***t I want to know where it is is it the nut under the battery tray Shocked
Nat-T
PostPosted: Tue Dec 04, 2012 9:54 am Up
Its on the side of the gearbox behind the passenger wheel arch liner, basically fill it through this hole until it starts to run back out. Hope that helps mate
Euro/Smoothed 2003 China Blue Verve
Rayvern Hydraulics
Schmidt 3-piece splits/Mercedes Wheels + custom adapters to 5x112
Lots of smoothed custom bodywork Wink
Deano
PostPosted: Tue Dec 04, 2012 10:40 am Up
Cheers mate I wil have look after work thanks
cosmicdance
PostPosted: Tue Dec 04, 2012 11:12 am Up
The whole point of this forum is so that people can get help and advice on their cars when they're fixing them.
I don't have a manual for my car and have found answers, and given them back too, for most queries.
I have used this site ever since buying my Peugeot 206, 3 years ago.
However, it amazes me why retards with nothing else better to do have to reply with window licking comments like 'buy a manual' and 'Use the fill / level plug on the gearbox'.
If you cannot string a constructive sentence together then don't post as it doesn't help anyone.
Andy
Andy
PostPosted: Tue Dec 04, 2012 1:57 pm Up
Empty
Fill
Deano
PostPosted: Wed Dec 05, 2012 4:52 am Up
Thankyou cosmic dance that is exactly what this forum is meant to be about and he says he retired from givin info but starts givin comments like that obviously I don't know where the fill level is otherwise I would not of asked and thankyou again Edward u have been very helpful through out can't wait to get the paint on this week and get car back on road wkend
