Latest: morgan20
Overall: 17135
Online Now [91]:
Visitors: 90
Today: 12304
Total: 110564577
Forums › The Car › 206 Problems › Lost keys
Lost keys
Deano
PostPosted: Mon Dec 17, 2012 3:10 am Up
Hi everyone my brother has lost his only key for his 206 1 litre 2005 reg what will he need to change I have a idea of what he needs to change just making sure not forgetting out
Ecu
Bsi
Ignition barrel
Door locks
Boot locks
Keys
Am I missing anything ? And do they have to be off same year donor car ? And say size engine ? Any help would be great thanks
Tolkienfan001
PostPosted: Mon Dec 17, 2012 3:20 am Up
Trade Rating: +13
New key from dealer?
2005 1.4 16v Sport
Check out my 206 here!
Andrew
PostPosted: Mon Dec 17, 2012 3:22 am Up
Does he have the car's owners book from Peugeot? It should have a security card for the key, take that card to the dealer for a replacement key
My 206 thread
www.detailedbyandrew.com
Tolkienfan001
PostPosted: Mon Dec 17, 2012 3:31 am Up
Trade Rating: +13
While we are on the subject I only have one key. I have the card with the code. How much would the dealer charge for a new key with remote central locking etc?
2005 1.4 16v Sport
PostPosted: Mon Dec 17, 2012 3:45 am Up
I got a key for a 207 which was about £200. Still less than all them other parts.
Deano
PostPosted: Mon Dec 17, 2012 4:06 am Up
So u think it would be cheaper for locksmith he sayin lot done for 210 no it cat d so it only had 1 key no service history
Deano
PostPosted: Mon Dec 17, 2012 4:07 am Up
Tolkinfan it's probaly cheaper to get key cover on your insurance that's what I might do because I only got one key for my gti. Aswell
Deano
PostPosted: Mon Dec 17, 2012 4:10 am Up
Surely must be able to get all them parts from scrap yard just need to know if that's all I need and can they be off any year car ? Then I can.ring round for price
PostPosted: Mon Dec 17, 2012 5:00 am Up
Just go to a good autolocksmith and ask them for a new key. They can clone the immo chip and program the central locking.
Just as a comparison, Peugeot will charge £90 just for the fob and cut blade. It will then need pairing with the car which could be another £60-£70
Ecu
Bsi
Ignition barrel
Door locks
Boot locks
Keys
You won't need a boot lock as it's controlled by the central locking. You will need the petrol cap though. Make sure the donor BSI has the same features (or more) than the original. No point getting one from a car with no fogs and no auto lights if your car has them as they won't function and the option may not be able to be activated in the BSI.
You will also need the chassis number of the donor car for future use. If you ever need a second remote, the dealer will be able to get the codes required.
Not 100% but I think the ECU part numbers will have to match. No point sticking an ECU on a TU1 that is set up for a TU5 engine.
PostPosted: Mon Dec 17, 2012 9:12 am Up
I was in Tesco earlier and I'm sure I saw something to do with key coding there...cheap blade and fob from Ebay....
Deano
PostPosted: Mon Dec 17, 2012 2:52 pm Up
He got it sorted today played a few locksmiths off got job done for 120 bargain thanks again for info
