Latest: Puggingalong
Overall: 17129
Online Now [237]:
Visitors: 236
Today: 16523
Total: 101711487
Forums › The Car › 206 Problems › Replacing BSI
Replacing BSI
karimali831
PostPosted: Sun Dec 16, 2012 5:29 pm Up
Hi all,
I am looking to get my BSI changed over for another, I can't send my BSI away from repair as I need the car on daily basis and I can't get a second hand BSI to program with my ECU so looks like I have to get the lot, BSI, ECU, trans. locks etc.
I can buy the equipment but will it be an expensive job to replace and I won't be needing dealer for the job? Can they also change the mileage to what it was set to my old BSI?
206 GTI 180
Deano
PostPosted: Mon Dec 17, 2012 3:51 am Up
No I think if your new bsi got more Milage it will stay the same but if it got less Milage your clocks will go to that I think that right way round mate
Deano
PostPosted: Mon Dec 17, 2012 3:53 am Up
No it the other way round to stop the car been clocked
Mate search it's on here some where mate
southwestchap
PostPosted: Mon Dec 17, 2012 3:57 am Up
Isn't the mileage programmed and remembered by the speedo cluster?
I changed a BSI, ECU, and key on a D-Turbo 206 once, pretty sure the mileage stayed the same.
PostPosted: Mon Dec 17, 2012 4:12 am Up
ON a multiplexed 206, the mileage is stored on both the BSI and the clocks. If your new BSI has more miles on it, then the clocks will show the new reading. If it has less, then it will stay as it is. Similarly if you change the clocks, it will always go to the higher reading. Don't know what would happen if you changed the dials and the BSI together. Guess it would still show the mileage from the donor vehicle.
On pre-plexed the mileage can be adjusted by putting clocks in with lower mileage or getting the storage chip reprogrammed.
karimali831
PostPosted: Mon Dec 17, 2012 7:11 am Up
I just bought this:
cgi.ebay.co.uk/ws/eBay...#vi-ilComp
Can anyone pick out if it was removed from a 180 or normal GTI and is it expensive to install?
206 GTI 180
southwestchap
PostPosted: Mon Dec 17, 2012 7:16 am Up
says 180 on the ECU in the picture i think? whether thats relevent
karimali831
PostPosted: Mon Dec 17, 2012 8:04 am Up
Thought the same but when I called up they didn't sound sure, if the BSI part number matches mine it should match and start no problem?
206 GTI 180
southwestchap
PostPosted: Mon Dec 17, 2012 8:11 am Up
thats what i went on, when i changed that Dturbo one. all the BSI, ECU numbers matched the originals i had on the car.
