Posted: Fri Dec 21, 2012 4:37 pm |
So... Just got home obviously with my lights on. And tried to turn them off when I parked up. Car was having none of it. My main headlights will not turn off. All other lights inc rears and sides are off.
Solution??
I don't touch fuses btw ever since I spiked my ECU and it cost £1000 to get fixed.
I know I've not been on here in a while and here I am crawling back back when I've got a problem and all that crap. But help please
P.S. Temporary solution - disconnected the battery
| China Blue 2.0 HDi DTurbo
-Sports Bumpers -Rear Spoiler -Rear Lexus Lights -SP Fuel Cap -SP Bonnet Vent -SP Upper Grille -SP Lower Grille (Zunsport) -Crystals | |
Posted: Fri Dec 21, 2012 4:46 pm |
take the bulbs out
| Ford Focus RS in white of course
filled with all sorts of goodies | |
Posted: Fri Dec 21, 2012 4:50 pm |
Trade Rating: +16
marc206 wrote: |
take the bulbs out  |
lol
i would rather unplug the headlights than the battery as you will mess up the bsi as the it will not be shut down in the correct way.
It's not plexed. It won't f*** itself. Ever tried to get bulbs out in the dark... Well Anyway I didn't think of that...
Posted: Sat Dec 22, 2012 8:52 am |
Its probly bsi related anyway so it will need a soft reboot...found on here in the HOW TO forum...
Posted: Sat Dec 22, 2012 9:04 am |
bezford wrote: |
Its probly bsi related anyway so it will need a soft reboot...found on here in the HOW TO forum... |
If the headlights passed through the BSI on a pre plexed, you'd probably be right, but they don't.
It's more likely to be the switch.
Fuse 10 (40A) under the bonnet is a simple way to turn them off. The headlights (dipped and main) are the only thing passing through it so you should be alright pulling it.
Posted: Sat Dec 22, 2012 11:07 am |
I've got myself a new 'stalk' to pick up on Monday on the advice of Addaz (he's a god)
Hoping it'll fix it (:
Posted: Sat Dec 22, 2012 12:56 pm |
Trade Rating: +16
Twidly wrote: |
It's not plexed. It won't f*** itself. Ever tried to get bulbs out in the dark... Well Anyway I didn't think of that... |
i ment unplug them not take the bulbs out
Posted: Sat Dec 22, 2012 3:03 pm |
anton1989 wrote: |
Twidly wrote: |
i ment unplug them not take the bulbs out |
That bit was in reply to the bit you'd quoted and to that guy too... To everyone.
Posted: Sun Dec 23, 2012 3:46 am |
Yeah but if the batterys been off without the right procedure its gonna need a reboot anyway...
Posted: Sun Dec 23, 2012 4:25 am |
No it won't because it's pre plexed. It'll be fine. I've done this plenty of times before.
Posted: Sun Dec 23, 2012 2:05 pm |
Oh hey there retard
| Team Impossible Possible
Posted: Mon Dec 24, 2012 8:24 am |
Addaz wrote: |
Oh hey there retard  |
I am the retard?
The switch didn't work. I wiggled a wire in my H4/H7 adaptor and they went off. They now work properly
Posted: Mon Dec 24, 2012 10:29 am |
UPDATE: Drove 10 miles... When I got there, they wouldn't turn off again... Opened the bonnet and wiggled the green block that on my H4/H7 adaptor and they went off.
What is that bit? Don't think it's a loose wire because I wiggled all the wires and it did nothing... Gave a dropped it and they went off ?! WTF?!
Posted: Mon Dec 24, 2012 11:18 am |
Sounds like the relay in the adapter has gone!
