Latest: tbafonso
Overall: 17130
Online Now [613]:
Visitors: 612
Today: 34445
Total: 102049503
Forums › The Car › 206 Problems › tyre pressure
tyre pressure
Go to page Previous  1, 2
Mattie-RS
PostPosted: Thu Dec 27, 2012 6:05 pm Up
Having lower pressure means more contact with the road. Start low because once the tyres get warm increase in pressure due to heat will go to a optimum pressure. I run 23 front because I know it will end up at 26 psi
Running higher than that and it will increase even more and will overheat the tyre loosing grip and ruining the tyre
This is from Toyo tyres on the R888's
VEHICLE WEIGHT COLD PRESSURE HOT PRESSURE
Very Light < 800kg 17 - 22 psi 22 - 29 psi
Light 800kg - 1000kg 20 - 26 psi 24 - 32 psi
Heavy 1000kg - 1400kg 23 - 27 psi 28 - 40 psi
Very Heavy > 1400kg 27 - 35 psi 37 - 40 psi;
Page 2 of 2
