Posted: Tue Dec 25, 2012 9:28 am |
If u havnt eliminated exhaust already start car and run in tickover then while running get w cloth in your hand and hold it over the exhausts opening at the back of the car...hold it there for just a few seconds and see if gasses are "blowing"along the length of the whole exhaust???u should be able to pin point a leak in the approximate site of any leak by the hissing,blowing noise...if it has a leak that is....try not to breath the gasses tho.
If u do it alone first to see if there is a hiss/blow and if u hear a leak but cant locate it get someone else to hold the rag over the end of the exhaust...dont cover it for over 5seconds or so...
Dont forget to lift the bonnet because the blow may be coming from the manifold???let us know...
Posted: Tue Dec 25, 2012 6:38 pm |
Hi Bezford
Many thanks for advise, I went out in it today on a 30 mile round journey. It is now Missfiring on start up and still very noisy on acceleration. There is a loss in power, in so much its taking longer to build up speed, once i reach 50mph and above and cruise, come of the accelorater; the noise stops. It starts again as soon as i use accelorater or when the autobox changes down the gears. I will get the garage to look at it after Boxing Day when they reopen. I will ask them to use a code reader to get any fault numbers, will then post the results on here.
Fas
Posted: Wed Dec 26, 2012 1:50 am |
Seems to much of a coincidence that its not got something to do with the cam belt. & I still reckon you should not be driving it till you 'at least' check the tensioner.
Posted: Thu Dec 27, 2012 8:11 am |
HI E5GDM
Thanks for your assessment/reply, Im thinking that way as well now, (CAM realated) as the loud tapping sound on acceleration, sounds like something is hitting something when i accelerate. BUt, i no very little, just basing it on my replies from the brill members on here. I still have not heard back from garage as yet, rang today and left a message on answerphone. Which suits me actually as i have gone down with Bronchitus, and don't really want to have to go out in the damp. I Will ring them again tomorrow, but its looking like they must be closed until next week. I am a member of the RAC, but all they will do, is take me to a garage if they cant fix it, and if they are closed, there is no point in me ringing RAC. Thanks again for taking time to reply.
FAS
Posted: Thu Dec 27, 2012 6:18 pm |
It might just be the belt hitting something due to a cover not being replaced properly, or the tensioner not adjusted correctly. Get well soon as well
Posted: Sun Dec 30, 2012 9:23 am |
Hi
Thanks for that, E5GDM, sorry for delay in replying still poorly and still no reply from Garage. Think they must have closed until after New Year.
Happy New Year to you all.
FAS
Posted: Thu Jan 03, 2013 7:54 pm |
Hi
I am on the mend now, at last; rearing to go now. I Will ring RAC tommorow and go from there. The garage has not replied, I have sent 4 e-mails and left one phone message over the Christmas/Newyear Period. I dont intend to go back to this garage, as i have left 4 e-mails and 1 phone message since 23rd December!!! I have been really ill, and have had no reply from them! After they did all work ( cost me over £300.00) for an MOT and then a week later the Cam Belt; because they could not do it at the same time as MOT as they were to busy. Thats when the problems started with my car.
Posted: Thu Jan 03, 2013 11:21 pm |
If it turns out to be a problem with the cam belt, get an engineers report & try to get your money back from the garage that fitted it.
Posted: Fri Jan 04, 2013 12:20 am |
ermm you have checked the oil level havent you?
dont believe the display if it says ok - best to manually check just to be sure
Posted: Fri Jan 04, 2013 7:25 am |
Hi
Thanks very much for advise lads, still no contact from garage and I am waiting for a dry day to ring RAC and get a report. Then i will go and see them if they are fault. I havnt checked oil yet, but i have asked the garage had they topped it up along with lots of other questions. I will check oil level shortly, if it is above the marker, how would i drain some out? as Ive never done this before?
Thanks in advance.
FAS
Posted: Fri Jan 04, 2013 10:11 am |
If its too high you'd need to remove the sump plug & drain some out.
Posted: Fri Jan 04, 2013 10:21 am |
Thanks for that, it is too high.
FAS
Posted: Fri Jan 04, 2013 4:45 pm |
Hi All
Thanks for all of your help and advise on my car issues, i managed to talk to the garage owner this afternoon and have arranged to take my car there on Monday for them to look at, he said if its their fault he will fix it. I willl get the RAC out on Monday and get them to look at it and then take me to garage if they cant fix it. Garage said they havnt put any oil in my car otherwise they would have charged me for it! When i mentioned it could be the Timing belt he seemed to go on the defensive saying, we were only asked to fit the timing belt and thats all what we would have done! I will keep you all informed on what transpires to be the problem.
FAS
Posted: Mon Jan 07, 2013 8:00 pm |
Update will be interesting.
Posted: Mon Jan 07, 2013 8:32 pm |
Too much oil is best lowered by oil filter removal...providing you can get it off and on without damage...
The filter is better because u only take a filters worth at a time...full sump plug off will go all over and be difficult to get the plug back in with oil gushing out...
