Posted: Sun Dec 23, 2012 3:19 pm |
I know this is the door strap bit, but can this be quick fixed... or will it need to be replaced. Have tryed WD40 but doesnt seemed to have worked 100% made it slightly quieter.. but still has that strange creek... also seems like its looose is it safe to tighten those bolts? Could that also be part of the problem
THanks ![Smile Smile](images/smiles/icon_smile.gif)
| | ![](images/spacer.gif) |
Posted: Sun Dec 23, 2012 3:32 pm |
Trade Rating: +16
had the same problem. just replace them very very easy to do
Posted: Sun Dec 23, 2012 3:45 pm |
anton1989 wrote: |
had the same problem. just replace them very very easy to do |
whats it like taking the door card offf, does everything snap and crumble lol any heads up to buy stuff before i do the task so i can replace the damaged bits taking it apart
Posted: Sun Dec 23, 2012 4:03 pm |
not a big job getting the cards off, just look for hidden screws like the the one near the door jam (hinge side) and the one inside the handle. Also it kinda clips on the top first and then hangs down,so taken it off is the reverse of this.
| 206 1.9D, 210,000 now dead following failed submarine experiment (flood) | |
Posted: Sun Dec 23, 2012 4:39 pm |
Trade Rating: +16
each door card is 4 torx screws then pull it off. the clips that hold the door card on always snap, there pennies from dealer
Posted: Sun Dec 23, 2012 5:29 pm |
Cant you use some good grease on the strap/mounting???
Posted: Tue Dec 25, 2012 3:21 am |
bezford wrote: |
Cant you use some good grease on the strap/mounting??? |
has worked on drivers side, but passenger still bad.. seems almost like the bolts are slightly looose need to get a socket and check them
Posted: Sat Dec 29, 2012 12:18 pm |
Problem fixed.. the bolts were loose once tightened and re-greased shes silky smooth again ![Razz Razz](images/smiles/icon_razz.gif)
