Latest: Beduff1977
Overall: 17134
Online Now [580]:
Visitors: 579
Today: 80195
Total: 108416523
Forums › The Car › 206 Problems › wet
wet
206lxdmart
PostPosted: Mon Dec 24, 2012 3:03 am Up
drivers side front and rear floor is soaked when i pulled mats up is there any way to drain this or dry it out and how could the water of got in its a 5 door cheers
merry christmas
PostPosted: Mon Dec 24, 2012 3:21 am Up
Windows not shut, blocked drain holes at bottom of doors, door/window seals perished, sunroof leaking, door cards removed and not been resealed. They're the places I'd start looking. Gone through any deep water recently?
Get a Vax and suck the water out and dry the carpets off as much as you can using it. You're going to have problems with the car fogging up at this time of year. Ideally you could do with putting it in a body shop oven for a couple of hours to get some heat into it to dry it out properly.
anton1989
PostPosted: Mon Dec 24, 2012 3:56 am Up
Trade Rating: +16
What do you mean reseal the door cards mate? I have this problem checked all the above apart from this? Mine not that bad and only happens when very bad rain
138Andy
PostPosted: Mon Dec 24, 2012 4:40 am Up
is the heater on your feet? if soo then the airvent thingy near your feet, my old 106 used to do it if i didnt close have it on the "blowing window" mode Wink just dont park it while the AC thingys are warming your toes Wink
206lxdmart
PostPosted: Mon Dec 24, 2012 4:47 am Up
i shal go and check the seals and see if i can see any leaks cheers guys
206 5 door black cyclones tinted back windows
jk206
PostPosted: Mon Dec 24, 2012 5:56 am Up
Check the door membrane (foam behind door card) for tears and rips, I had a wet passenger footwell at the front which was down to a small hole at the bottom of the membrane so I smeared silicone over it and its now sealed
bezford
PostPosted: Mon Dec 24, 2012 7:08 am Up
You may have a gromet missing on the bulkhead or...im not entitely clued up on tjis but someone else may know but...there's a rrasonably common fault with the heater matrix or something like that results in a puddle inside...i cant remember where i read it but its defo a fact...i will consult haynes later on...last minute shoppin beckons.
R.HYDE
PostPosted: Mon Dec 24, 2012 10:10 am Up
There's a drain hole on the bottom, front/inside the door frame and I bet that's blocked.
Fifer
PostPosted: Tue Dec 25, 2012 3:48 am Up
Have you lost any engine coolant. Can sometimes be caused by a cracked or leaking heater matrix.
1.4hdi 02
206lxdmart
PostPosted: Tue Dec 25, 2012 8:13 am Up
no it still full of coolant noticed door rubbers look wet on the bottom maybe leaking through there
