Posted: Fri Dec 28, 2012 4:17 am |
Hi all.
Ive just installed a new Head Unit but it wont work.
Halfords have said i need to take the cable attatched the the rest of the cables to a perminant live? there is a ignition switch already there but i need a perminant live for the memory???
I have got the cable to under the steering wheel on my 206 but not sure how to identify a live?
i hate driving without music and i do alot of driving for work....
i start work again on wednesday so need this done asap!
any help would be appreciated!
Posted: Fri Dec 28, 2012 5:21 am |
If you put it on perminate live every time you would start the car the battery would be flat- they must of of said ignition live
Posted: Fri Dec 28, 2012 5:22 am |
so which is the ignition live?
Posted: Fri Dec 28, 2012 5:23 am |
When the key is turned the headunit has power
Posted: Fri Dec 28, 2012 5:28 am |
but my last head unit had power when the key was turned but thisone hasnt?
Posted: Fri Dec 28, 2012 5:29 am |
Probably burnt the fuse that was my first guess
Posted: Fri Dec 28, 2012 5:33 am |
halfords have said a need a perminant live?
Posted: Fri Dec 28, 2012 5:35 am |
No you don't otherwise every time you'd start your car it won't due to a flat battery- check fuses
i put my old radio back in and it works.... so how could it be fuses?
Posted: Fri Dec 28, 2012 5:36 am |
How could it be perminate live then?
Posted: Fri Dec 28, 2012 5:37 am |
i need a perminant live for the memory of the unit? stops it going back to factory settings?
Posted: Fri Dec 28, 2012 5:38 am |
Ahhh just a sec need to find a photo
Posted: Fri Dec 28, 2012 5:40 am |
Do you have a connector like this?
You need red going into yellow
Posted: Fri Dec 28, 2012 5:42 am |
reds going to red and yellow is going to yellow. swap them round?
Yep
