Latest: jackrox1992
Overall: 17186
Online Now [1056]:
Visitors: 1055
Today: 175191
Total: 148698506
Forums › The Car › 206 Problems › Rear axle costs and labour costs?
Simmo
PostPosted: Tue Jan 01, 2013 4:13 pm Up
Sorry if there is already a topic about this, I have searched but didn't find anything much helpful. My cars rear axle on the right (drivers side) is very loose, my local garage quoted me dangerous and £576 for repairs. Would you say this sounds right? And does the whole rear axle need replacing? Is there any shortcuts to this???? The car is still drivable at the moment but it is risky and dangerous by which I mean if I hit a hard bump or hole it may collapse....... Sad
1.1 silver style www.206info.co.uk/Foru...52484.html
PostPosted: Tue Jan 01, 2013 4:16 pm Up
Ssp engineering. Google it.
iainlovatt
PostPosted: Tue Jan 01, 2013 4:56 pm Up
Get a second hand axle . About 100 quid pay garage about £70 as its only a hour joby.
(My Garage)
DanT
PostPosted: Tue Jan 01, 2013 5:08 pm Up
Generally the easiest way is to replace the axle rather than repair the one thats there.
As mentioned labour should only be an hour or two tops. So i'd budget £100 ish for that.
Can get a second hand axle or a refurbed one.
Second hand will be around the £100 mark as mentioned, a refurbed one will probably around £250-300 from the likes of IM Axles or similar.
donnypaul81
PostPosted: Wed Jan 02, 2013 2:22 pm Up
Ricky rpm in Barnsley did back axle on my saxo think it cost £190 and was done in an hour or so he might have 1 he might not but its full of scrap yards round here. Not sure if the axle is similar to the saxo but you might just need new bearings putting in on the stub axle. Just Google Ricky rpm or find him on Facebook he does a lot of french car repairs builds them races them etc
donnypaul81
novatron1_2
PostPosted: Wed Jan 02, 2013 6:50 pm Up
I did this some years back, I used one of those online scrappies sites where you fill out what part you need and different scrappies get back to you, cost £150 delivered and look almost new as the scrappies promised!
206 1.9D, 210,000 now dead following failed submarine experiment (flood)
