Online Now [319]:
Visitors: 318
Today: 62605
Total: 106039693
Forums › The Car › 206 Problems › side airbag
side airbag
sheerness
PostPosted: Wed Jan 02, 2013 4:34 pm Up
Hi there again pug friends..
another day another problem, when we got the pug, the airbag light would flash all the time and the light next to that (yellow) looks like 2 people sitting with a belt across and side bags was on solid..
i have got a diagnostic kit with PP2000 to find out the fault and get it fixed. on the report it said the airbag ecu was at fault, so we have replaced this and the flashing light had stopped but the one that is next to it is still on and solid,
we have run the diagnostic again and it has come back with no faults whatsoever, do i have side airbags? i know there is one in the dash for front passenger and one in the steering wheel for the driver as they have the AIRBAG logo on the cover of them but i cant seem to find anything to suggest that i have side airbags......
also there are no wires at all under the seats so we can rule that one out. any help with this would be great guys, thanks in advance
Cars a 206 1.6l Roland Garros W-Reg (2000)
Regards
Dom...
bezford
PostPosted: Thu Jan 03, 2013 4:35 am Up
The side airbags will be easily visible on the outer sides of the front seats uppers...if u look and they dont jump out they aint there...as for saud light il have to have a look at mine...
R.HYDE
sheerness
PostPosted: Thu Jan 03, 2013 5:00 am Up
hi bezford thank for your reply, Nope there are no sign of anymore airbags, So this solid light is a mystery,
any info you can find on yours in regards to the solid light will be great,
thanks again
Dom.....
PostPosted: Thu Jan 03, 2013 6:05 am Up
Sounds like your passenger side airbag is turned off. Is it still the man with the belt across (might have x2 written next to it)
Down below the ignition is the key hole to turn the airbag on/off.
sheerness
PostPosted: Thu Jan 03, 2013 12:29 pm Up
hi there steve206 thanks for your reply, yeah there is a key system to turn on and off the passenger air bag, when the air bag is turned to off the airbag icon stays lit and the one next to it with 2 people with a belt across also stays on, and when turned to on the airbag light goes off so that is the correct operation for that system but the belted one still stays on, grrrr
Dom.....
bezford
PostPosted: Thu Jan 03, 2013 2:07 pm Up
i havnt had chance to look but its not a seat belt warning light is it???ive never really noticed it???
R.HYDE
PostPosted: Thu Jan 03, 2013 2:31 pm Up
Never known an early 206 to have them...maybe I dont drive mine enough!
PostPosted: Thu Jan 03, 2013 3:21 pm Up
Post a pic of the light?
PostPosted: Thu Jan 03, 2013 3:30 pm Up
If you do a diagnostic again does it recognise the airbag ecu?
sheerness
PostPosted: Thu Jan 03, 2013 3:53 pm Up
hi there and thanks again guys,
here is a link of the light the is solid on the dash board
i1293.photobucket.com/...67db91.jpg
steve206 we have run the diagnostic again since the new airbag control unit and there are no faults at all on the airbag ecu..... plus the AIRBAG Light next to the solid light at the moment does not flash so working as it should.
Regrds
Dom.....
bezford
PostPosted: Thu Jan 03, 2013 6:54 pm Up
Seat belt warning...try putting both front belts _into thete slots whle u sit in drivers seat and belt is in on passenger seat with no body sat on that side see what happens???if goes out note it...then get a passenger in aswell and put the belt on proply so your both sa as normal with front belts on...see if it goes out???then try it with bth belts clipped in to slots but no body sat in car...see wha happens and report back???
R.HYDE
Mattie-RS
PostPosted: Thu Jan 03, 2013 7:33 pm Up
Checked the seat belt tensioner?
PostPosted: Fri Jan 04, 2013 4:58 am Up
Never seen that light before!
PostPosted: Fri Jan 04, 2013 6:00 am Up
Front and side airbag warning light.
Did you clear any crash data from the replacement airbag ECU?
Did you change any settings using PP2000? There is a function where you can tell the ECU which airbags are fitted. If you fit seats without airbags, and the ECU thinks they should be there there, the light comes on. Change the setting and the light goes out or on, depending what you click.
Go back into PP2000 and check to see which airbags the ECU says should be fitted, and deactivate the ones you don't have.
The seatbelt light is red.
sheerness
PostPosted: Fri Jan 04, 2013 6:28 am Up
Hi and thanks for all your input, I am going to have a look at the pp2000 again and see if anything under the airbag is flagged up I shall keep you informed!...
Kind regards
Dom.....
