Latest: Beduff1977
Overall: 17134
Online Now [438]:
Visitors: 437
Today: 23295
Total: 107204201
Forums › The Car › 206 Talk › question needing an answer pls help
dan_manu
PostPosted: Thu Jan 03, 2013 12:41 pm Up
does a gt front bumper need sports wings to fit? or would it fit with normal non sport wings?
thanks dan
PostPosted: Thu Jan 03, 2013 12:46 pm Up
No it doesnt, you might find the arch liners a bit tight though.
dan_manu
PostPosted: Thu Jan 03, 2013 12:50 pm Up
phew! it came with inside arch covers also , thsnk you very much for your help
PostPosted: Thu Jan 03, 2013 12:55 pm Up
GT bumper was never fitted to sports wing when it appeared on a 206 from the factory.
dan_manu
PostPosted: Thu Jan 03, 2013 12:57 pm Up
ahh right so what were gt wings like then? non flared?
PostPosted: Thu Jan 03, 2013 12:59 pm Up
Normal wings with little arch trims on them - not normal SP arches.
dan_manu
PostPosted: Thu Jan 03, 2013 1:00 pm Up
ahh so il be fine then, thanks for you info , much appreciated
macj
PostPosted: Thu Jan 03, 2013 2:50 pm Up
And your only allowed to fit them if you are going to rally your car Laughing
dan_manu
PostPosted: Thu Jan 03, 2013 2:51 pm Up
rally it round maccies car park Wink
macj
PostPosted: Thu Jan 03, 2013 2:58 pm Up
only if you do the drivethru at over 40mph
PostPosted: Thu Jan 03, 2013 3:12 pm Up
arch liners will fit fine as gt's had non sport wings the same as your car Smile
