Latest: tbafonso
Overall: 17130
Online Now [191]:
Visitors: 190
Today: 14432
Total: 103681290
Forums › The Car › 206 Talk › help pls before i smash my 206 to bits
dan_manu
PostPosted: Sat Jan 05, 2013 5:34 am Up
has anyone got any tips on getting mushroom clips off??? as iv been tearing my fingers to bits trying to get one from the inside of my arch near the spring to take the bumper and arch covers off for about an hours !!!!!
anton1989
PostPosted: Sat Jan 05, 2013 5:37 am Up
Trade Rating: +16
lol you just pull the middle bit out 1st, get a flat head screw driver under there
L5_UKS
I normally just use a flat ended screw driver, but yeah I agree some of them are b******s to get out.
anton1989
PostPosted: Sat Jan 05, 2013 5:39 am Up
Trade Rating: +16
iainlovatt
Dan use a screw driver.. Pull the middle pin out and wala off it comes!
(My Garage)
iainlovatt
PostPosted: Sat Jan 05, 2013 5:40 am Up
also passing through 5:30 today if you need any help
(My Garage)
oldskoolz
PostPosted: Sat Jan 05, 2013 5:42 am Up
get a fork from your kitchen, works a treat Wink
Black 206 Gti. Soon to be 2.2
Tolkienfan001
PostPosted: Sat Jan 05, 2013 6:03 am Up
Trade Rating: +13
Yea I used a fork. Never had a problem that way
2005 1.4 16v Sport
Check out my 206 here!
DeadEyePaul
PostPosted: Sat Jan 05, 2013 6:09 am Up
Use a fork young padawan
dan_manu
PostPosted: Sat Jan 05, 2013 7:25 am Up
got em off thanks for info and now i cant get the fog connectors off!!! fml
iainlovatt
PostPosted: Sat Jan 05, 2013 7:31 am Up
lol Get a screw driver and prize the metal clips pin thing!
(My Garage)
DeadEyePaul
PostPosted: Sat Jan 05, 2013 8:10 am Up
Those metal pin clips are designed to be pushed in- then you pull the cable.out
iainlovatt
PostPosted: Sat Jan 05, 2013 8:14 am Up
I know Good look with that! They are a pain the a**e to push down, and only sometime will the connection pop off. Just taking the clip off is quicker and pain free. Im sure a lot of people will agree. Smile
(My Garage)
PostPosted: Sat Jan 05, 2013 8:31 am Up
I use a sharp screwdriver and then some circlip pliers to remove the plugs from my car.
dan_manu
yeah i was pushin it in so jus pulled it off n it came off Smile thanks,
now my biggest problem yet is inside the arch there's a 10mm bolt to take off the bumper n thats the last one but the bolts rusted at the bottom so it jus spins, i just dno what to do, iv put some oil on it to hopefully harden it up and try later otherwise im jus gona angle grind me bumper off! i dont want to but kinda stuck
any help would be very much appreciated
