well you need something to pull the winder lock,use a thin flat head screw driver,or a thin bar with a hook head,so you can see the lock which look like an OHM symbol,just pull it out,and be careful that it snap in your face or eye.
and to see the look,push the door car a bit,and you will be able to see it.
