Latest: tbafonso
Overall: 17130
Online Now [54]:
Visitors: 53
Today: 6267
Total: 103936701
Forums › The Car › 206 Problems › 206 1.6 16V Accelerator Pedal Sensor problem
kinetic
PostPosted: Mon Jan 19, 2015 12:06 pm Up
Hi all,
I have a 1.6 16V 206 car. My problem is, the accelerator pedal does not work suddenly. Even if i push it to the end, no rpm changes. If I stop and work engine again, it works normal.
I take it to the service, they connect the car to pc, and they say "Accelerator pedal sensor" fails. We need to change this part. But this part is very expensive(almost 350£). Part code is 1920-x1.
Are there anyone who has seen this problem before?
kinetic
PostPosted: Mon Jan 19, 2015 12:29 pm Up
Part image added. Where can i buy this part?
PostPosted: Mon Jan 19, 2015 12:39 pm Up
Peugeot, euro car parts, scrap dealers, gsf
kinetic
PostPosted: Mon Jan 19, 2015 12:49 pm Up
can you give a link?
PostPosted: Mon Jan 19, 2015 1:08 pm Up
That part you have displayed is for a HDI, you probably require the throttle body they mean.
Here is a link for a throttle body:
They need to be coded and the throttle position set by peugeot planet
www.eurocarparts.com/t...ervice-kit
The potentiometer/throttle pedal sensor is Peugeot only for new
kinetic
PostPosted: Mon Jan 19, 2015 1:15 pm Up
Thanks. How did you understand it is for HDI? At service, the pc showed the same part, even the image was the same.
PostPosted: Mon Jan 19, 2015 1:39 pm Up
I agree with Addaz,the pic you shown is an HDi engine,as the 1.6 16V don't have this part,your car got an Electric throttle body,that needs to be configured ,and learned.
kinetic
PostPosted: Mon Jan 19, 2015 2:49 pm Up
I think you are not right. Because when i am coming this image's page, i select 1.6i 16v 110. And also 2 peugeot services said the same.
PostPosted: Mon Jan 19, 2015 3:10 pm Up
Well the above image is listing a maf, which yours doesnt have and nor does yours have a COMMON BLOODY RAIL
We need more info on what is required
PostPosted: Mon Jan 19, 2015 3:14 pm Up
The picture is of the DW10 lump.
kinetic
PostPosted: Mon Jan 19, 2015 3:15 pm Up
they say accelerator pedal sensor fails. also give the code 1920 x1. What can it be if it is not this part? Can you send the image?
PostPosted: Mon Jan 19, 2015 3:23 pm Up
Kinetic; listen to Addaz and Timon2222. They are some of the most knowledgeable people on this forum. If they agree they will not be wrong.
kinetic
PostPosted: Mon Jan 19, 2015 3:29 pm Up
Ok but i m just trying to learn. If you are right, The peugeot auto services in my city are not saying the true. What can i do in this situation? I wanna earn some information from your experiences.
kinetic
PostPosted: Mon Jan 19, 2015 3:42 pm Up
I wanna explain my problem again.
Accelerator pedal does not working for random times.(5 times in 10km, no fail for 300km, 2 times in 50km)
The car works normally but pedal does not work even if i push it to the end, and no rpm change(like i am not pushing it)
I stop the car and start the engine again, it works for the 1st or 2nd or 3rd time.
It fails 1st or 2nd gear, not at the first start of the engine.
I am confused that if it will be occur at high gears. There is an accident risk.
PostPosted: Wed Jan 28, 2015 1:19 pm Up
You got a PM long time ago,but you didn't reply
