Online Now [519]:
Visitors: 518
Today: 38874
Total: 105480902
Forums › The Car › 206 Problems › Radio volume problem
WendyJ
PostPosted: Thu Jan 10, 2013 1:01 pm Up
I've got a 206 53 reg and suddenley the volume on the radio/cd increases all on it's own. I have to fight with it by pressing the volume down button while it's trying to increase until I can get it to a low volume and then quickly switch it off.
This happens whether the engine if running or not but not all the time just randomly!
PostPosted: Thu Jan 10, 2013 1:03 pm Up
Does it happen more when they have the travel news on?
If TA is displayed on the MFD, press the TA button on the radio and turn it off.
I'm fairly sure that you can turn the TA volume down in the settings too.
Mine used to do it until I turned it off. Gives you the shock of your life when it suddenly starts booming at you.
206gti_chris
PostPosted: Thu Jan 10, 2013 1:21 pm Up
i get this problem if i use the volume dial on the stereo, but if i only use the stalk control it doesnt?
20Drift
PostPosted: Thu Jan 10, 2013 1:30 pm Up
Have you checked for any loose/faulty wiring at the back of the unit?
devotedsniper
PostPosted: Thu Jan 10, 2013 2:33 pm Up
Dunno if the 206 has it but it's the same stereo as my 307 (i assume you have the standard one?), go in options and turn off the auto volume control.
It's meant to change the volume depending on the noise level but it just seems to have a mind of it's own on my car (seems to increase volume when slowing down rather than when i boot it).
Now a 2010 Renault Megane Coupe owner
