Latest: Puggingalong
Overall: 17129
Online Now [136]:
Visitors: 135
Today: 36024
Total: 101730967
Forums › The Car › 206 Problems › Require engine mounts 03 plate gti
shelley13prince
PostPosted: Thu Jan 10, 2013 2:59 pm Up
HELP, girl confused need the engine mounts garage say one over gear box and one for left side, looked online there's loads and garage say dealer charge £90 each, obv cheaper to get myself but unsure which ones to get and where from, the car slams in 2nd if lift off clutch too quick and its because of the engine mounts, any ideas for this damsel in distress lol
Big_Rich180
PostPosted: Fri Jan 11, 2013 5:36 am Up
Try Euro Car Parts.
PostPosted: Fri Jan 11, 2013 10:14 am Up
Eurocarparts have two websites:-
www.eurocarparts.com/
www.carparts4less.co.uk/
If you order online carparts4less is usually cheaper. Odd but they are the same company!
Also try:-
www.buypartsby.co.uk/
Is there a specialist peugotr parts supplier anywhere?
Yellow pages and your local motor factor may be cheaper than all these.
Do not be tempted with cheap Chinese imports (or even expensive Chinese imports) as you will do the job again in 6 months!
PostPosted: Fri Jan 11, 2013 10:26 am Up
If you want some 2nd hand mounts in good condition I have the two you want. I only removed them to fit the Vibra Technics mounts to restrict engine movement which would otherwise stress the Maniflow manifold.
