Online Now [398]:
Visitors: 397
Today: 42001
Total: 105370488
Forums › The Car › 206 Problems › Indicators
Indicators
djoggie
PostPosted: Sun Jan 13, 2013 5:28 pm Up
When i indicate right and turn the steering wheel back to central position the left indicator comes on???
only happens when i turn the wheel a certain distance round.
is there something i can do or do i have to replace? if so how?
PostPosted: Mon Jan 14, 2013 1:55 am Up
New comms unit I think. Not cheap though.
djoggie
PostPosted: Mon Jan 14, 2013 3:49 am Up
why would the ecu control the auto cancel? surely its either a bit snapped off or the indicator gone wrong?
PostPosted: Mon Jan 14, 2013 4:24 am Up
The comms unit is the module with all the stalks attached (around the steering wheel) which includes electronics and is not the ECU or BSI.
djoggie
PostPosted: Mon Jan 14, 2013 8:08 am Up
so i need to change the indicator stick then?
PostPosted: Mon Jan 14, 2013 1:18 pm Up
No the comms unit. That's what the indicator plugs into.
PostPosted: Mon Jan 14, 2013 3:44 pm Up
Depends on the age of your car. My daughters (pre plex "W" reg) was a simple fix by removing the steering surround, removing the indicator, carefully taking apart the switch section of this, cleaning and re-assembling.
Can't recall all the detail of exactly how it all came apart now as it was well over a year ago but the indicator has worked without problem since. If I recall correctly the switch was full of brass filings and taking it apart and re-assembly was easy to do.
