Posted: Tue Jan 15, 2013 3:15 pm |
Trade Rating: +13
Hi
Do all 206's have a blown bulb warning? How do I know if I have abulb Warner?
Posted: Tue Jan 15, 2013 3:51 pm |
Don't believe any of the peugeot 206s have a blown bulb warning.
Posted: Tue Jan 15, 2013 3:58 pm |
nope none of them do, only really seen that tech in bmws
Posted: Tue Jan 15, 2013 5:01 pm |
Vws have them. Even Nissan bluebirds used to have the function.
Posted: Tue Jan 15, 2013 5:04 pm |
Mercs have them as well/
Posted: Tue Jan 15, 2013 5:17 pm |
206 have them..
For indicators.
Posted: Tue Jan 15, 2013 5:30 pm |
207's have it! Well mine did, did not like smd's even with can us canceller
Posted: Tue Jan 15, 2013 5:48 pm |
Vauxhalls have it.
Posted: Tue Jan 15, 2013 6:07 pm |
I know another make that has it.................
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
Posted: Tue Jan 15, 2013 6:33 pm |
Lol I think it's pretty obvious if 1 of your head lights have gone
Posted: Wed Jan 16, 2013 1:11 am |
Trade Rating: +13
That's the answer I wanted thanks
Posted: Wed Jan 16, 2013 5:20 am |
Not if your brake light has gone though and you get pulled over! Or reverse light in my case.
Posted: Wed Jan 16, 2013 7:05 am |
All simple things that should be checked weekly. Anybody that doesn't spot a headlight being out must be thick.
Posted: Wed Jan 16, 2013 7:34 am |
Trade Rating: +13
The issue is not a headlight being out. I want to get an LED fog bulb and the don't work if u have a bulb Warner.
Posted: Wed Jan 16, 2013 7:58 am |
Tolkienfan001 wrote: |
The issue is not a headlight being out. I want to get an LED fog bulb and the don't work if u have a bulb Warner. |
They do if you connect the right resistor in the circuit.
Suppliers charge more for error free bulbs when in fact you only need to pay 10p for a resistor. It's just a case of having the knowledge to solder it into the circuit.
