Latest: Beduff1977
Overall: 17134
Online Now [618]:
Visitors: 617
Today: 113310
Total: 109967858
Forums › The Car › 206 Problems › what sensor
what sensor
hampshire1
PostPosted: Sat Jan 19, 2013 4:15 am Up
hi all can anyone tell me what sensor runs the temp guage on the dash.
206 1.4 hdi. 2003.
i have wild movement of the needle, one second its on zero then up in the red with stop light flashing. stop for 2 mins and its back to zero then 70 -90. other times i can go for 50 miles with the guage not reading at all.
water and oil fine.
most of the time it acts normaly. am i right in thinking this guage is oil level/temp?
206 1.4 hdi 2003
PostPosted: Sat Jan 19, 2013 4:42 am Up
Only temp guage a 1.4 HDi has is the coolant temp.
